Question about Moen Plumbing
Replace moen 1255 cartridge on 7590 faucet - Moen Plumbing
  • 92 Answers
SOURCE: Replacing Moen 1225 cartridge.
you will need a puller more then likely but what you can try is a little wd-40 lubricating spray
Posted on Feb 05, 2009
  • 659 Answers
SOURCE: Moen 7065 leaking at base of lever control in kitchen faucet
Yes, a cartridge will probably solve it. There are two different Moen cartridges so be sure to take the old one with you so you get the correct one.
Posted on Apr 05, 2009
jj505
  • 195 Answers
SOURCE: Loose handle on my Moen single handle kitchen faucet
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Thanks and Please Rate jj505
Posted on Apr 06, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
FixinFax
  • 3085 Answers
SOURCE: need to replace cartridge in single lever moen
Turn off water
Remove the handle with an allen wrench, usually 1/8".
Unscrew the dome with a pair of channel lock pliers with a rag to prevent scratching.
Wiggle out the old cartridge with the channel lock pliers.
Clean all innards with WD-40.
Reverse procedure
Posted on Dec 12, 2009
Testimonial: "Thank you for the speedy reply it was needed at the time because the part was jammed or at least it seemed so."
How do I remove the cold water faucet cartridge on a Monen high arch, 2 handle w/sprayer, series 7700 Montecello
  • How to Fix Leaking Moen High Arc Kitchen Faucet -DIY blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html Video embedded · Our Moen high arc kitchen faucet started to leak around the base of the high spout. We had the Moen Monticello 7700 series single handle faucet for 8 ...
  • Frequently Asked Questions (FAQs) Regarding Moen Faucets www.moen.ca/consumer-support/faq ... a cold water filtering faucet, ... tighten the cartridge nut or replace the cartridge. If the faucet has a handle connector: ... Remove the faucet handle.
  • Monticello by Moen - Monticello www.moen.com/monticello/_/N-1z141yd Monticello. Chrome replacement handle knob insert ... As the #1 faucet brand in North America, Moen offers a diverse selection of thoughtfully designed kitchen and ...
  • Installation Help / Animated Tutorials for Moen Faucet www.moen.ca/consumer-support/installation-help Moen's animated tutorials provide installation help for many of Moen's ... How to Remove & Install the 1222 Cartridge. ... Removing a Single-Handle Kitchen Faucet ...
  • Contractor John replaces a cartridge in a Moen faucet ... www.youtube.com/watch?v=FqzpRE-MmEo
    • BY CONTRACTOR JOHN
    • 11 MIN
    • 279K VIEWS
    2011-10-26 · Contractor John replaces a cartridge in a Moen ... Repair Moen Single Handle Faucet, ... How to remove an old kitchen faucet and install a ...
  • May 05, 2016 | Plumbing
    I need to change the 1255 cartridge on a Moen Benton Faucet.
    Usually they unscrew. Sometimes if the faucetis in a hardwater zone the mineral deposits build up and make getting the dome off very hard. Use a strap wrench to get a little more grip, this will prevent damage to the finish and allow you to twist harder.
    Dec 27, 2013 | Moen Benton High Arc Kitchen Faucet with...
    Leaky faucet
    This is generally due to a loose or faulty cartridge. To fix:
    1. Turn off water supply valves under sink.
    2. Block the sink drain to avoid losing small parts.
    3. Remove faucet handle. It is attached by a set screw, an odd size (I actually used a T9 torx screwdriver successfully, even though the set screw is hex head, since I did not have a matching allen key). The set screw is quite far into the handle, ~3cm, through a hole in the bottom of the handle. Depending on your countertop layout, you may have to actually remove the entire faucet from the countertop in order to get access to it, in which case follow the appropriate parts of your faucet installation directions in reverse.
    4. Remove dome. It will come off with a gentle turn/pull.
    5. Check the tightness of the exposed large hex nut. This is the piece that holds the cartridge in place. If you are lucky, it is just loose, and that's your problem; otherwise you will need a new cartridge.
    6. Unscrew that nut, remove. Pull out the cartridge.
    7. Replacement cartridges may be found at your local Moen dealer, or may be ordered directly from Moen +1-800-Buy-Moen. Parts are free due to the lifetime warranty. Part #1255 includes the cartridge, cartridge nut, and set screw. The nut must be changed with the cartridge (presumably due to its wear characteristics).
    To reassemble:
    8. If you have it, place a very small amount of plumber's silicone lubricant on the back of the cartridge, on the rubber seals around the three holes.
    9. Assemble in reverse order of disassembly. The cartridge only goes in one way, due to three guiding channels on its perimeter.
    Enjoy!
    Oct 08, 2012 | Moen 87877SRS Haysfield Spot Resist One -...
    Moen Eva two handle lavatory faucet - hot water leak from faucet. Old cartridge removed (had to get a special tool to remove it), new cartridge installed, and leak fixed. Four days later, leak is back...
    Hot water side of most faucets give most problems try heating with hairdryer pryor to trying to remove,contact moen tell them of your situation they will more than likely send you a new cartridge free of charge if you raise enough stink about just replacing cartridge.
    Jun 08, 2011 | Moen T943/MO4999 Eva Deck Mount Whirlpool...
    Handle won't stay up
    I did the same thing recently, that is replaced the cartridge on my moen kitchen faucet to stop and leak, and I also have the same problem. I called moen back and they sent me another cartridge that was supposed to fit tighter, I suppose. I just put the new one in and it still wont stay up. I'm going to call moen one more time and then I guess I'll have to buy another faucet, but NOT moen!!! Good luck with yours.
    Jun 05, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
    How do I get to the valve cartridge to replace it?
    how to replace moen cartridge for two handle kitchen faucet ... cartridge for two handle kitchen faucet exporters,how to replace moen cartridge for two handle kitchen faucet suppliers,how to replace moen cartridge ...cn-faucet.com/ kp-how-to-replace-moen-cartridge-for-two-handle...
    Mar 17, 2010 | Moen Bathroom Sink Faucet - 4-inch...
    Replace cartridge in Moen kitchen faucet and now
    it probably has a plastic cartridge,remove it, and push the center piece out slowly and firmly. wipe this down,not completly this is what carries the wieght of the handle.give this a shot.
    Jan 12, 2010 | Moen 7437 Chateau Single Hole Kitchen...
    Moen Single Handle Shower Faucet leak...
    the cartridge if defective,replace it and your leak will stop.
    Jul 22, 2009 | Moen & One Handle Tub & Shower Faucet
    Apr 05, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
    Plumbing Logo
    55 people viewed this question
    Top Moen Plumbing Experts
    john h
    Donni Steen
    Don Numinen
    Don Numinen
    Are you a Moen Plumbing Expert? Answer questions, earn points and help others
