Question about Kenmore 43142 Front Load Washer
Kenmore dryer (electric )
Kenmore dryer works, but getting no heat (electric dryer)
I have a Kenmore Electric dryer Model # 11066812694. It will not get hot. Everything is functional but the heating mechanism. I removed the two screws from the top lint screen, as well as the panel from the back. I vacuumed the lint trap and the air wheel. I have removed the thermal fuse as suggested in a previous posting. Which seems simple enough for a woman to do. :) Now, I'm ready to go to have the part tested for functionality. In the event that it is not the thermal fuse, how do I get to the heater element and is it going to be more difficult to replace? Because I honestly think that this has been way too easy and I have a feeling that I am in for a big surprise!I have a KicthenAid Clothes dryer. However the Parts are the same as the Kenmore. I have the kit and have installed the TPC. I am stuck installing the fuse because I have a 3/16" terminal and don't quite get the instructions. I understand the female/male being put on one end of the jumper wire. What I am confused about is removing the 3/16" terminal from the harness and attaching the female end to the wire. Is that with the jumper wire? Where should it be connected?
Mark
    Top Expert:
  • Kenmore Master
  • 78,919 Answers
YOU WILL NEED TO REPLACE THE DRYERS HEATING ELEMENT, IF U TOOK THE DRYER APART TO CHECK THE THERMAL FUSE THEN U CAN DO THIS, i WANT YOU TO GO TO THE LINK BELOW FOR HELP WITH THE PART REPLACEMENT, U CAN ALSO BUY THE PART AT THIS SITE.
http://www.repairclinic.com/0047_8.asp
hERE IS A PHOTO AND THE LINK FOR YOUR DRYERS HEATING ELEMENT.
http://www.repairclinic.com/Appliance-Parts?s=t-11066812694-%3d%3dc244
Posted on May 07, 2009
Kenmore HE 3 gas dryer model 110.92822101 will not heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 04, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore (model 96573230) will not heat even after replacing heating element
heatman101
Aug 21, 2011 | Kenmore 62602 Electric Dryer
Kenmore dryer will not heat up
I couln't bring anything up using the model number you gave, but generally an electric dryer will have heat if the heating element gets the signal from the switches and it is not open.
If everything works beside the heat, then I would make sure that the heat selector switch is operational and if it is then to replace the heater element.
Jun 17, 2011 | Kenmore 600 6963 Electric Dryer
Kenmore Electric Dryer model #11060812990, 80 Series - dryer is working but only blowing cool air.
heatman101
Jun 15, 2011 | Kenmore 659 Electric Dryer
Kenmore Dryer model # 110.-62942101 will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 13, 2011 | Kenmore 64742 Electric Dryer
My Kenmore electric dreyer does not heat? Vent is not clogged and blowing out freely. I have replaced the thermal Fuse, and the Multi temp switch kit and still no heat? The model No. is : 96573220 Kenmore...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Kenmore Dryers
Kenmore 11066812694 dryer whirring noise in back
Could be the rollers holding up the drum, or the motor blower fan.
Jan 18, 2010 | Washing Machines
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping ...whirlpoolpartssurplus.com/cart/whirlpool-dryer-electric-h...
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. ...www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly. Before...ehow.com/how_5337380_replace-heating-element-whirlpool-di...
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Jun 28, 2008 | Kenmore Elite HE4 Electric Dryer
You will need to UNPLUG the dryer and remove the back panel to access. The heating element is located inside the heater box on the right-hand side of the dryer (facing from the back). Simply disconnect, the wires leads and remove the mounting screws to remove.
Now...you mentioned removing the thermal fuse. Did you check the thermal cut-out or the hi-limit thermostat? These components are small silver disc-shaped devices mounted on the heater box assembly. As you are facing the back of the dryer, the hi-limit thermostat is located near the terminal connections of the heating element. The thermal cut-out is located farthest away from the heating element closer to the top of the heater box. Usually when you have a no heat problem, it the thermal cut-out, hi-limit thermostat, or heating element that goes bad. If the thermal fuse is bad, you generally have a dryer that not only won't heat, but won't even turn on. I hope I'm not confusing you. In a nut shell, there's a difference between the thermal fuse and the thermal cut-out. If you had large accumulations of lint in your dryer, I would bet you have a blown thermal cut-out.
If you wish to check the parts listing yourself to make sure you have the correct parts, go to searspartsdirect.com, type in your model number and look under the "Bulkhead" heading. The thermal cut-out kit is what you need to order for a no heat problem. It's listed as item #1 (part #279816). This also includes the hi-limit thermostat. It is recommended by the manufacturer to replace BOTH of these components at the same time. The heating element is listed as item #14 (part #279838).
Look under the "view diagram" heading and you can see where all these components are located, using the exploded view of the dryer assembly. The thermal fuse you mention is listed as item #59 in the drawing and is located on the air baffle housing.
This is still an easy fix. I just want to make sure you're identifying the correct parts. I don't think you want to purchase parts you don't need.
I hope this helps you. If I've managed to confuse you, please post back with your questions and I can guide you in the right direction.
Apr 16, 2008 | Kenmore 43142 Front Load Washer
Kenmore 43142 Front Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
