Question about Minolta Maxxum 5 / Dynax 5 35mm SLR Camera
Shutter release problem
Camera was working fine .went to change lens and now makes shudering noise as if searching for lens. when pressing shutter release nothing happening execept when you look in the viewe finder the anti shake is at full and does not change.when switching camera on camera makes above shuddering noise.its as if camera has lokced its self completely or maybe the anti shake has malfunctioned. it wasopped the other day.
  • Minolta Master
  • 5,412 Answers
Try removing the lens and the battery and leaving it for 24 hours - this can happen when the gremlins get into the works !
Posted on Jul 24, 2017
  • 667 Answers
SOURCE: My camera doesn't work when I press the shutter release
I think the timing of the shutter winding gears has slipped a tooth or two. look at the picture in this image:
Near the motor drive coupler at the bottom you will see a blue and a white gear. Look closely at the blue gear and you will see a line on the top of it. That line needs to be pointed at the center of the white gear when the camera has been released and ready to be advanced again.
If you wish to proceed, I will tell you how to re-time the gears.
Posted on Feb 28, 2008
  • 185 Answers
SOURCE: fungues? What does it look like
Take the lens off and look through the finder. is the mold still there? if it's not then it's in the lens. look through the lens and you will see the mold. it's usually between the lens elements and depending on the kind of mold it can be very hard to remove.
take or send your lens to a camera repair shop for an estimate before having it disassembled and cleaned.
Posted on Feb 03, 2009
  • 22 Answers
SOURCE: my X700's shutter isn't working when i press the shutter release
There are actually two capacitors, one on the bottom of the camera, the other on top, just beneath the film speed selector. these are both 220uF, 4V electrolytics. they can be successfully replaced with 220V 6.3 volt capacitors (tantalums are best), provided the size is essentially the same. Just make sure you install the capacitors the same way, as incorrect polarity will cause the caps to fail. check out for detailed instructions.
Posted on Jul 13, 2009
  • 44 Answers
SOURCE: Minolta X 300 camera On replacing batteries
on this camera can you lock shutter button down?
may have moved it changing battery.
take out battery may release it
is battery up the right way?
Posted on Feb 15, 2010
  • 175 Answers
SOURCE: i cant see through the
Remove the lans and make sure the mirror is in the down position. If not, then camera repair is probably needed.
Posted on Dec 31, 2010
Olympus E-300 Evolt when you press the shutter button to take a picture, the shutter rapidly repets for about 9 times
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 27, 2011 | Olympus Cameras
I get error press shutter release on both lenses
try these:-
  • connect it to pc and on it
  • vaccum the barrel of lens
  • changing mem. card and batt. for 2min.
  • shake it.
  • on and off in different positions
  • hit the part near lens softly with palm (trust me this made mine work)
Aug 11, 2009 | Nikon D60 Digital Camera
I have two different lens one is stronger than the other.Sometimes I take the perfect picture then other times not so good.How do I know which lens to use for close up or i want a distant shot at a cl
Do you mean that, you press the shutter release once and the shutter stays open until you press the shutter release a second time. If so, check your shutter speed setting. If it is set to "T" (Timed Exposure) the camera is working correctly. Change your shutter speed to an appropriate setting, such as 1/125. If that does not solve the problem, you might need to take it in for repair.
Nov 10, 2008 | Nikon F65 35mm SLR Camera
Faulty nikon d40
That may be the best advice :
Jun 21, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
Apr 15, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Rebel 2000 went retarded
I got a Rebel 2000 off ebay, and it had the same problem. The Shutter wouldn't open, it showed dead batteries, and the mirror hung until I pressed the shutter button or changed modes.
After a good deal of surfing, I found that the most likely reason was a sticky/oily shutter
Since I didn't have much $$$ invested in the camera, I tried cleaning the shutter curtain with Qtips and alcohol. After a little cleaning, the shutter started to move. After a lot of cleaning, the shutter moves freely. I ran a roll of film through it, and it seems to be working just fine now.
Feb 27, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
I had the same problem but replaced the lens with a different lens and it worked just fine.
Aug 27, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
D50 won't take a picture!
I was having the same problem.. And since I could not afford to take it to the shop, I tried everything I could think of...
Then I fixed it!!
It seems that the slide door behind the shutter was stuck for some reason... If you remove the lens.. (make sure the camera is in manual mode)... snap a shot so the shutter is up.. then gently slide the panel in the back down....
Once I did that.. the camera was working again.... Hope this easy solution works for you guys....
Feb 03, 2007 | Nikon D50 Digital Camera
No picture is taken when shutter release button is pressed
Are those NiMH batteries? Have you tried resetting the camera? If no standard way, just take out batteries for a few minutes, the more the merrier, let the tension build, and replace them. Try tapping on the lens area, it might loose something up. Best I can do, know it aint much ;] Good luck!
Jun 01, 2006 | Nikon COOLPIX Cameras
Minolta Maxxum 5 / Dynax 5 35mm SLR Camera Logo
361 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
Are you a Minolta Photography Expert? Answer questions, earn points and help others
