Sca125-3 reznor heater
Service manual
2 Suggested Answers
  • 79 Answers
SOURCE: need a manual for Reznor unit heater UA 40
Reznors website is: www.rezspec.com
go to their home page and click on the "manuals & media" tab. You will find the folders on that page for installation,parts,and servce manuals. After you find the manual you are looking for you can download it for free. Good luck!!
Posted on Nov 20, 2009
How to test thermo disc safety on reznor hanging heater
Brian, it is a very simple task to perform but for a novice YOU MUST HAVE THE POWER OFF !!!!!!
At Harbor Freight you can buy a cheap digital multimeter for about five bucks. After turning off the power, remove one wire from the thermodisc and use the resistance scale to check continuity. If it reads no continuity, the switch is OPEN and bad. If it reads continuity it is CLOSED and is good.
If you have a system that is not heating, did you check the top right side (facing the unit) of the Reznor heater for a 'manual reset' hi-limit switch ?? If not, do that first and listen for an audible 'click' as you depress the little red pushbutton. If you hear a click, turn the power back on and set the thermostat setpoint above room temperature and see if the heat now comes on.
Dec 02, 2015 | Heating & Cooling
Smell gas in garage after reznor heater shuts off
sounds like the gas valve is leaking through.
have it checked out asap gas leaks only get bigger.
Feb 12, 2015 | Reznor Hanging Furnaces-Power Vented-...
Reznor UDAP 100 tripping Flame Rollout Switch
If the flame is rolling out of the heater then the burners of heat exchanger is blocked needs cleaning
Feb 19, 2013 | Heating & Cooling
Reznor heater manuals
SERVICEMANUALS @ COST www.mauritron.com Manuals at free download: homeappliance.manualsonline.com/manuals/.../lg_air_conditioner_product_list.html Helpful?
Dec 19, 2010 | Heating & Cooling
Reznor heater troubleshooting manual
Dec 16, 2010 | Heating & Cooling
Need a manual for Reznor unit heater UA 40
Nov 20, 2009 | Heating & Cooling
I have an old reznor model us-100f, the heater will run for approx. 10 min. before blower fan will start to run
Your fan switch is most likely bad. Need to replace.it with a new one. Not hard to replace just take old one to a AC supply house and they will match it. Or go on line to Reznor and they will have it, Just need the model number of unit. Rus
Nov 07, 2009 | Heating & Cooling
Oil burner/waste oil heater not firing
Don't know what model Reznor Waste Oil heater you have but I happen to own a Reznor RA235. 235,000 BTU. If there is no oil being pumped up I would first check to see that the filter isn't clogged where the oil sucks up from the tank. There should be a gauge on yours with different color codes as to when the filter must be changed or cleaned. I already had to replace the pump on my Reznor RA235 as the pump went bad a couple of years ago. You can tell if it is pumping or not. There is also a filter built right outside of the pump on mine and one up on top of the unit that need to be cleaned at times. The manual shows all of this.
Jan 04, 2008 | Heating & Cooling
Heating & Cooling Logo
53 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
