Question about Microwave Ovens
Error code E005 on siemens
Can not turn oven on
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Hi I have a siemens inno-wave HF17055GB Microwave and the plate turner is not turning, otherwise it seems to be working? help please
Replace the motor. The teeth in its gearbox have probably been damaged when trying to turn the plate by hand.
Aug 25, 2014 | Siemens HF17055GB Microwave Oven
KitchenAid KHMS155LSS when press "bake potato" button,start flashing error F3
Question: Error Code - Oven - F3 Error Code - F3 E0 Answer Product Symptom:
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Jul 31, 2014 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Siemens Innowave 'n890l6u5 rsgs'
sadly you destroyed the unit only option is replacement of same
Aug 11, 2017 | Siemens Microwave Ovens
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
Code e on only two of the right hand zones on siemens induction hob
Hello.
These codes mean that the oven's electronic control hasdetected a condition it needs to check which mean error. When you see a code,follow these steps to solve the problem:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on.
Thanks.
Sep 07, 2011 | Microwave Ovens
Siemens HF 87960 GB Microwave/Combo Oven
Please, Can somebody tell me where can I get one of this oven??? Thanks Andy
Dec 08, 2007 | Siemens HF87950GB Convection Microwave...
Microwave Ovens Logo
473 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
