Question about Bosch 33618 1/2" 18v Cordless Drill Tool Only + Case
1) No variable speed; 2) Grinding sound when using , although drill still works
I have a Bosch Brute 18v, there is no variable speed and in there is a grinding sound, but the drill works.
  • enginuitysho May 27, 2009
    rowdy45176, it's a Bosch Brute18v 33618 cordless 1/2" drill.
    Thankyou for your help, John
  • David Ford
    David Ford May 11, 2010
    ok for starters you need a switch and give me the model number and I will find a breakdown and see what the grinding noise might be, but it sounds like you also need a gearbox.
  • 2,176 Answers
Starting with the variable speed the switch part # is 2607200457 and list for 47.58, the gearbox part # is 2606200930 and lists for 75.90 and lastly the motor part # is 2607022865 and lists for 75.90, the grinding could be the motor bearing going out or the magnets cracked, if you want to tackle this I suggest going to Boschtools.com and on the left side towards the bottom type in your model number so you can look at a breakdown of this tool. Before I started spending that kind of money I would think about possibly replacing it. If I have helped you would you please rate my response accordingly and Thank you.
Posted on May 27, 2009
Variable speed not working, the trigger is either full on or off. speed switch 1 or 2 works
Replace the switch because a power mosfet inside is defect
650583-6 look for that switch partnumber also ferify it because this is for the model in the netherlands but most time its the same by Makita and its not to expensive will succeed to replace succes. but be careful when pulling out the wires using a thin watch screwdriver to push the unlock holes next to the connector contacts.
Nov 01, 2015 | Dewalt Makita Bhp452 18v Cordless 1/2"...
Bosch cordless drill not working.
First The model is pretty new. you need to register your tool on line. this takes you from a one year warranty to a three year warranty. They will give you a pro-vantage number. with that said it sounds like a trigger switch. Yhe trigger switch is the brain of your tool. not only does it do your variable speed but it also controlls the brake and your fuel gauge. Because of the cost I highly recomend taking it to your closes Bosch service center.
Oct 13, 2012 | Bosch Cordless Impact Driver, 18V, 1/4 Dr,...
The variable speed function is controlled by the switch. If you only have off and full on, the only fix is to replace the switch (Bosch Part Number 2607202013).
Mar 14, 2012 | Bosch 23618 18V Cordless Impactor...
I have a Bosch 1/2"
Sounds as though you are on the right track. I would take it apart, and see if the trigger could have some dirt or other material causing it to stick, or is it worn to the point that it needs to be replaced. Good luck!
May 30, 2017 | Bosch Tools 8.0 Amp Corded Hammer Drill,...
I have a Bosch 18v Brute Litheon cordless hammer drill and impact. One of the batteries works just fine. The other one will not take a charge. The set is about 6 months old. Apparently it's been this...
you have a bad battery (defective) take the unit back to where you bought it and hopefully they will understand and exchange it out for you. If the dealer won't help you can contat the Bosch company, they typically will do an exchange even if you dont' have the receipt, (a courtesy exchange). You may have to pay to ship the defective battery to them. If you can prove when your purchased the system you will have less difficulty convincing them to give you a new battery. good luck with this, my experience with Bosch has been that they are a customer friendly company and should be willing to help you,as I would hope your dealer would
Mar 22, 2011 | Bosch 18V Brute Tough Drill with Blue Core...
Ryobi 18v variable speed impact driver. I need to know something about speeds and settings. Bob
Just keep it on high, vari-speed on an impact driver is not very useful unless working with delicate materials.
Mar 23, 2010 | Ryobi 18v Variable Speed Impact Driver...
How to change the chuck on a draper red line 18v cordless drill
The screw you are trying to remove is left hand thread. You must turn is clockwise to remove it.
Hope this helps
Apr 15, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
I need to remove the chuck on my Bosch 33618 Brute cordless drill. How do I do it?
You must remove the inner chuck retaining bolt first, it is a torx screw and is left hand thread. once you have this screw out, get yourself a 1/2" allen key (the L kind). Chuck the short end in the chuck to grip it, use a mallet to hit on the long end (this will unthread the chuck). The spindle thread is regular Right hand thread. It may take a few good hits to knock it loose but it will come off.
Mar 31, 2009 | Bosch 33618 - 2G Factory - Reconditioned...
Bosch 33618 1/2" 18v Cordless Drill Tool Only + Case Logo
223 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
