How do u wire a fasco motor model K628? I have a rheem unit but noticed wires where not all connected ! Would like to get a diagram to show me how to wire
2 Suggested Answers
SOURCE: Wiring Diagram for a Emerson Motor in a Tempstar Central A/C
EMERSON 1/4 HP MOTOR 5 WIRES BLACK BLUE BROWN WHITE RED LOST MY DIAGRAM 115V1075 RPM 3 SPD HOW DO I WIRE IT TO THE COMPRESSOR
Posted on Jun 08, 2010
What fasco motor wiring diagram?
there is a wiring diagram on the motor. Usually has a yellow brown white brown black. Black= line voltage Yellow= common and the two browns go to capacitor.
Jul 19, 2014 | Fasco 1/6hp 825RPM 5.6 Diameter 208-230...
Fasco model d917 wiring diagram
Well, a Fasco is a generic brand name of HVAC replacement motors.... a little more information would be helpful....like the wire colors???? Each Fasco motor has a wiring diagram on its side and is self-explanatory. Post a picture of the diagram and it will be much easier to walk you through the procedure.
But TYPICALLY....white is common
black is high speed
red is low speed
blue and yellow is medium low and medium high
two brown wires go to the capacitor
Some manufacturers have oem motors that have a few different colors.
May 13, 2014 | Goodman Heating & Cooling
Fasco d236 replaces 7190-1186 u90B1 - wiring cross reference?
Is this a water heater blower? Or HVAC?
Post question on water heater forum:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
I do not have HVAC resources
Add a comment and say what you discover
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 28, 2013 | Water Heaters
Need a wiring diagram for rheem electric water 50 gallon 2007 model
1) Copy following links for standard wiring that applies to all brands electric water heater: wire colors vary, and do not matter.
You probably have ordinary residential non-simultaneous water heater.
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
http://waterheatertimer.org/images/WH-w-combined2-1000.jpg
2) Look at tank label.
Typical label will show number of elements (upper and lower)
And give wattage for each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html#label
http://waterheatertimer.org/images/Whirlpool-energy-smart-watt-rating-IMG_2600.jpg
Notice also total connected watts.
If total connected watts is same as individual upper or lower element watts, then you have ordinary residential non-simultaneous tank.
Mar 07, 2013 | Water Heaters
FASCO A173 draft inducer motor wires to capacitor
on most capacitors there are terminals that bare set as parallel dashes or t bars. A wire to either line of bars or one to t and one to bar. --as long as they are on different lines is all that matters
Feb 17, 2013 | Tools & Hardware - Others
Do you have a wiring schematic for a Rheemglas model 81V66DB ser # RH0500408476?
I can't identify that model number, and Rheem does not show that model:
Open following link to help identify water heater:
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
Contact Rheem:
http://www.rheem.com/Contact.aspx
Oct 07, 2011 | Water Heaters
I need a wiring diagram for Fasco model #659 serial # 447621 ceiling fan, heater, light unit.
Yellow wire is light. Blue is vent. Red is heat element and fan after going through a circuit breaker and thermostat. Brown is night light. White is common to ventilator housing. Black is power to switch cluster.
Jan 25, 2010 | Fasco Dryers
Need a wiring diagram for emerson k55hweym 3739
green is ground. white is common. blue and orange are hi speed/low speed. brown goes to the capacitor.
Both motors should have the wire diagram on the side of the motor.
Jul 03, 2009 | Emerson Quiet Kool 10MW42K Air Conditioner
The central air unit connected to this heater was not working. We called a repairman who after taking the thermostat off the wall and then hooking jumper cables to the wiring inside the heater unit found a...
Call that serviceman back!
he did not want to run new wire so; he left you one wire short and, thought you wouldn't notice to fix this yourself i've included the proper thermostat wiring diagram at:
http://www.toad.net/~jsmeenen/wiring.html
May 03, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
35 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
