Question about Dryers
Bosch Maxx wtl 6101
The maintenance door opens automatically and water leaks out when the dryer is in operation and at the same time there is no water in the water container.
2 Suggested Answers
SOURCE: Bosch Maxx WTL 6100 tumble dryer - door switch
i have wtl 6100 bosch and the mashine is not running. There is power on the machine, it can run but it can not run and heat. I can get light in al the panel, but it is like it needs to be rebouted. I can get it to show 111,222,333 etc in the window but i cant get it to work
Posted on Sep 05, 2010
Bosch WTL 5200 door hook is broken. How do I open the dryer door to replace the door hook?
Normally you open these from the top screws at the back undo slide the top off and you can get access to the switch to replace
Jan 28, 2018 | Bosch Dryers
Bosch AXXIS WTL 86300 condensation dryer leaking water
It's a classical error code, you can find all the error codes together with the troubleshooter within the manual under this article:
Bosch Axxis Washer Manual
Nov 29, 2012 | Bosch Dryers
My dryer is leaking from the bottom. service man said either the tube or the pan is cracked. tube seems ok, so is the pan replaceable or glueable. could there be another reason to look for leak. dryer has...
Open the bottom front panel. Remove the heat exchanger. Take notice to see if theres any water in that compartment. Reach your hand towards the back of that opening to see if there is water pooling back there. If theres water present, then your condensation pump needs to be replaced.
also double check the connection of the drain hose from the dryer to the drain.
Jan 09, 2011 | Bosch Axxis WTL 5410 Electric Dryer
Bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
Nov 17, 2009 | Bosch Axxis WTL 5410 Electric Dryer
Oct 25, 2008 | Dryers
Bosch axxis wtl 5400 dryer
I found that the dryer will not start because the door isn't fully closed. My wife has basically split the plastic door a bit, but if you firmly close the door, it will start.
Jul 25, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Bosch maxx dryer
The manual for our Maxx WTL6500 says to press and hold the Start/Stop button for 4 seconds. "The child safety lock can be released permanently using the Menu button." In our case that means press Menu 3 times then press Change to set the lock on or off.
HTH
Jul 02, 2008 | Bosch Axxis WTL 6307 Electric Dryer
Bosch maxx wtl 6300 dryer when placed on a dry cycle it beeps every couple of minutes and stops and the filter light flashes. The lint filter is cleaned and it still does this any help?
Hi Guys...
At least I can shed some light on how to open the bottom part.
When you are looking into the dryer with the door open, take a look at the bottom hinge of the door. There is what looks like to be button popped out slightly..
Place your thumb on it and press. This should open the bottom part of the dryer.  Then clear out the gap between where the lint filter connects to the other units below it (when the door is closed...)
Hope this makes sense... there seems to be a sensor there..  I just cleaned mine so praying that the beeps stop.. Its been driving us mad for the last 8 months!
May 14, 2008 | Dryers
Dryers Logo
69 people viewed this question
Top Dryers Experts
