The sound totally stops working. Not on mute. Seemingly unconnected to any other event. Sometimes rebooting will restore. Dell XPS 600, MS XP Pro.
    President:
  • 2,923 Answers
Are you using a separate speakers or are you using the built-in speakers of your computer?
For this kind of problem, you need to isolate the problem. Please follow the steps below:
* If you are using a built in speakers, please follow the steps below:
1. Click the Start menu and go to the Control Panel
2. Go to Sounds and Audio Devices.
3. Check the volume properties. Make sure that all volumes are set to maximum and check boxes should be unchecked.
4. Go to Audio tab, click the drop-down arrow and make sure that it is set to generic computer speaker.
5. Click on Apply or OK.
* If you are using separate speakers (i.e. 2.1 or 5.1 speakers)
1. Connect different speakers to the computer.
2. Connect the problem speakers into different computers.
3. Check the Volume Properties under the Sounds and Audio devices.
These are the things that you need to do to isolate the problem. Otherwise, if same problem exist, you need to refer to the computer manufacturer for repair.
Have a great day!
Posted on May 07, 2009
Single touch to open and close the window is not working
Check settings in the Mouse or touchpad software. If this is a recent event try a System restore to a date before this issue. It may be a hardware failure. Take a look at Dell Support, it may be a common issue: http://www.dell.com/us/p/xps-13-l321x/pd Have you done ANY updates recently?
Apr 07, 2013 | Dell Ultrathin Xps 13 L321x I7-2637m...
I have a Dell XPS 600 Desktop. I have a new HDD SATA. I installed the new HDD and I try install Windows XP by pressing F12 to boot from disk. It take me to a screen where it says, Press enter to install...
Don't press F12, that tells the Dell to restore Windows from a hidden partition located on the original hard drive. Since you are using a new drive, you need to boot from the Windows XP CD and follow the instruction to load the operating system.
Oct 30, 2010 | Dell XPS 600 PC Desktop
Dell xps 600 won't boot
hard to say but you can try to repair the os turn your pc on and start pushing f8 it should open a restore panel one of the options should be repair try that
Feb 20, 2010 | Dell XPS 600 PC Desktop
D610 Dell Latitude no sound
try this>
start menu > control panel > sound speech and audio devices > sounds and audio devices > audio > check here is the default device selected for playback the right device if wrong correct it and reboot, if it doesn't work
try this thing go to device manager using following instructions
start>run> type in without quotes 'devmgmt.msc' > sound and game controllers
uninstall the all the drivers from it by right clicking and use the uninstall option
now reboot the system and reinstall all the sound drivers
please also check the mute option on the speaker present on the taskbat in bottom right usually
if this also doesn't work then
what we can do is do system restore to go back to a date when the sound was working but system restore will lead to loss of all the settings and programs that were installed after the date we restore it to.
to use system restore
here is a helpfull link
http://support.microsoft.com/kb/306084
Further queries are welcome
and if you find my solution helpfull please do rate me
and then reboot the system
Feb 20, 2009 | Computers & Internet
XPS 600 - Six Beeps No Boot
Follow this link and figure out what the beep code is telling you and i can try to help you fix it from there. I can tell you that what you are describing usually is caused by a hardware issue.
http://www.computerhope.com/beep.htm
Jan 22, 2009 | Dell XPS™ 600 PC Desktop
CPU Question Dell XPS
have you added new memory
does pc start at all
Jan 16, 2009 | Dell XPS 200 PC Desktop
Unable to reboot CPU
when its powering on let it get a little ways in then hold the power on off button until it just shuts off. Then boot it on and see if it gives you a safe boot option if it does select it. Then do a system restore to before this problem started. Hopefully this will restore the drivers.
Added more ram from 2gb to 8gb but still say only 2gb
1fb3933.jpg the above will help u..the OS will not support the RAM you have hence its not showing..hope it heps!
Nov 23, 2008 | Dell XPS™ 600 PC Desktop
No audio
check the audio sound settings in control panel, and make certain that there are No MUTE enabled.
Feb 26, 2008 | Dell XPS 600 PC Desktop
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
