Question about Kenmore Elite HE4 Electric Dryer
Kenmore range model 665.95822003 broiler will not turn off
The broiler will not shut off
SOURCE: Kenmore Model #790 - smooth top range
Probably not. It sounds like your broil element burned out. This just happens sometimes. If it is this , it will have visible chunks missing. Yes, It shorted with enough force to blow the main fuse. Unplug it as sometimes it can still be live and sparking when power is restored. Element is fairly cheap usually less than $50 and you can fix it yourself.
Posted on Jun 29, 2008
kachbibi1
  • 979 Answers
SOURCE: kenmore Electric Range both oven and broiler stop working
Check the breaker first, then the wiring in the back from the receptacle to the oven. Check to see if the wires in the plug are secure. Then look in the back side of the oven and you will find the wires attached to a connection box. This is where you should find your problem. If not here, your board could be bad. The replacement board is not that expensive. I really think the wiring is the problem since you have neither the top nor the oven working.
Posted on Jan 30, 2009
localwonder
  • 6784 Answers
SOURCE: oven quit working
Hi. this is common in many old gas range ovens. There is a set of coils that are attached to the gas valve assembly. These coils , when activated and operational, open and close the main and secondary valves in this unit. They are controlled by the main ERC(clock/oven control board). I recommend checking these coils and there respective wiring harnesses. if the clips and wires are worn and corroded, simply replace the entire wire harness.
Now, if the wiring harness and wires that are connected to the coils look good and there are no signs of corrosion on the wires and connector clips, this will confirm that the coils have failed and you will need to replace them.
You can also preform an additional test with a multimeter. simply connect your multimeter or voltage meter to both terminal posts located on the coils. once your meter is connected, start the oven cycle. you should register some sort of current during this test at this time. if the current is sufficient and the coils do not initiated the valve action, this will confirm coil failure. if the meter dosen't register a current during oven operation, this will confirm ERC(control) failure. you will have to replace the Oven control board in this case.
The Most common issue in this situation will most defiantly be the coil assembly and not the control.
Please rate and god bless:)
Posted on Apr 21, 2009
SolutionGuy
  • 331 Answers
SOURCE: Broiler won't turn off, how do I disconnect broiler?
Rojas,
I would seriously re-think your decision to get into this. The problem is the Bake/Broil selector switch and is REALLY difficult to explain how to replace. There are only 6 wires on the failed switch, but getting to it and wiring it properly is beyond the purview of this forum because the chances of mis-wiring it could cause; at best, another component failure and, at worst... serious injury or death.
I'm not kidding.
Generally speaking, hiring a professional tech to install this for you would run about $200. But that's peanuts compared to a new oven or an extended hospital stay.... or a funeral.
I really not joking.
Anyway, I hope you consider NOT getting in there since you don't know what you'd be looking for. Also... kill the breaker 'til you get this thing fixed.
I hope you consider my response to be a solution, because that's exactly what it is. Since you do, will you show me some FixYa love like I did you and rate this solution?
SG
Posted on Jun 03, 2009
muffteck
  • 202 Answers
SOURCE: I have a kenmore gas range model #790. When I turn
dont use it may blow you up bad gas valve and saftey sender
Posted on Mar 27, 2010
We have a Kenmore model C970-440994 and we had an F10 code appear and now the broiler stays on all the time, what is the problem?
Please shut off the circuit breaker or unscrew the fuse, or somehow disconnect this range from the electrical power source, or you may very quickly have a fire.
3 Likely answers to your problem.
1) The broiler control switch has shorted out inside, it has "burned up".
2) Two of the wires, or more, have shorted out inside the range and are touching, or have melted together.
3) Wires inside the wall socket are touching or have shorted out.
God bless your efforts.
Jan 06, 2017 | Kenmore Kitchen Ranges
Oven element
model T, either you have a stuck or shorted broil keypad or the relay on the board is welded closed. Try this, remove the back panel behind the control panel. Make sure the breaker is off to the range. Unplug the keypad ribbon cable to the main board. Power the unit back up. You should get an error code. Now if the broiler still comes on you know you have a welded broiler relay on the board. If the broiler doesn't come on..it's the keypad. Catriver.
Sep 19, 2007 | Kenmore 92002 / 92004 Kitchen Range
Oven/Broiler temp will only warm to low tempmax 237F
Check your thermometer! It appears it is working OK!
Jan 15, 2016 | Kenmore Kitchen Ranges
Kenmore range broiler doesn't work
What is the model number?
Feb 24, 2013 | Kitchen Ranges
Kenmore oven has f3 code
What you have is a fried relay on the board. the contacts are stuck, Find the board and yank out the wire marked Br1 and see if the broiler shuts down. Do youur findings while the machine is without power amigo. More than likely you needs an expensive new control board. You could just remove and tape off one of the broiler wires if the bake still works.
Apr 10, 2009 | Kenmore 95822 / 95824 / 95829 Electric...
Broiler shuts off after a few minutes of use
water pump probabley to slow causing overheat and shutoff some makes have variable speeds
Feb 03, 2009 | Kitchen Ranges
Kenmore Elite HE4 Electric Dryer Logo
27 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
