Question about Gateway Computers & Internet
Samsung 733nw monitor
Hello Sir, My Samsung Synchmaster 733nw (17") monitor is not clear as it used to be and some blurry lines are on it.First,I thought it was cuz of VGA cable which was very loose so I replaced it with a new one but same problem .Can it happen cuz of Nvidia drivers or something else?.I have Nvidia gt 220 1 gb DDR3 graphic card (Currently working on window xp cuz i have to transfer some data from my PC to Laptop)? Please help me as soon as possible.Thanks
SOURCE: al1917w lcd monitor resolution problem
Get a new video card, you dont need the best video card to support 1440*900. It is affordable and the best solution.
Posted on Sep 10, 2007
Benimur
  • 6966 Answers
SOURCE: Moving Horizontal Lines on LCD Computer Monitor (Windows XP2)
It is possible that what you are seeing is 60 cycles AC hum, but then again it may not.
Perhaps you can try increasing your Screen Refresh Rate to any other setting other than 60 Hertz. (Display Properties/Settings/ Advanced/Monitor)
If that does not work, you may need to check your wirings and/or the power supply of the monitor with particular attention to the filter/power capacitor.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Dec 09, 2007
skotkolr
  • 558 Answers
SOURCE: driver of samsung monitor
I will go with Cropp on this one however if you cant find it at that site you may also try driver guide.com
Posted on Jun 19, 2008
  • 300 Answers
SOURCE: "No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Posted on Sep 14, 2008
Rivernet1
  • 67 Answers
SOURCE: screen flickers in 1680x1050 - samsung 2232BW plus
Can your monitor AND PC put out that resolution??
I don't think your Dell and put that out, if it's an "old" machine.
Posted on Dec 02, 2008
Synchmaster 2333 no red color
Rush to claim your warranty, the only thing you should do first is make sure that the input signal is OK: Hook up any laptop to any other monitor, then immediately (i.e. without changing what the computer is showing) hook it up to your monitor.
Another option is that you have a faulty cable. If it is part of the monitor, the warranty will cover it. If it can be detached from the monitor, borrow another cable to see whether that is the faulty piece.
Feb 26, 2013 | Samsung Computers & Internet
Hello sir my samsung lcd monitor model no 740N . in dis monitor right side display two verticle lines green n light pink but hoe to i resolved dis problem please give me suggestion
You cant resolve it tiny resistors in the screen have failed and that is why the lines have appeared, it is a case of live with it or buy a new monitor
Feb 24, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
Half of the screen is black - Samsung SynchMaster 710N
hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Sep 05, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Facebook display problem Samsung SynchMaster 713BM monitor
it must be the drivers your using for the monitor. Have you checked the pins connector are all straight. as bent pins will cause this.
http://www.howtodrivers.com/model502115.html
webpage link for drivers
AndystUK
Vote me happy
Aug 31, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
HCL 17" monitor display problem
Hi there ,
It seems that you have a vertical section problem ,It might be possible some capacitor might have gone wrong
Jan 24, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Yellow lining problem
Turn on your PC, press CTRL-ALT-DEL and check on the tab processess if ehtray.exe is running. Ifso, kill it and see if the line disappears. do not remove the file, it is part of windows media player but known to cause problems, click here for more information and how to remove it from start up.
Aug 01, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
HOW DO I HOOK MY SAMSUNG SYNCHMASTER TO MY COMPUTER? I HAVE THE DVI CABLE CONNECTED TO BOTH AND IT KEEPS SAYING CHECK SIGNAL?
Prior to attaching the SynchMaster and if there is another monitor, pls try lowering the Screen Resolution of your Display Properties. It may also be necessary to lower down the Screen Refresh Rates. In some video card, you may have to activate Twin/Extended view or enable the use of a second monitor assuming that your regular monitor is connected to the standard 15pin VGA and that the Samsung would be the 2nd monitor using the DVI.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Thank you for using FixYa.
Apr 18, 2008 | Computers & Internet
Computers & Internet Logo
24 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
