Question about Bosch Als 2500 Electric Garden Blower/ Vacuum
Bosch als2500 cut out and won't restart
Used if for 1 hour it then cut out. Allowed it to cool down. Won't restart
2 Suggested Answers
wentlanv
  • 710 Answers
SOURCE: Bosch CCS180 18V lithium cordless
Hi ramzemail,
Welcome to fixya!
It sounds like the wire connection where you insert the battery is loose. So, when you give the battery a shove in, the connection tightens, then the vibration from use loosens it again. You would have to take the hand grip piece apart until you can see the wiring and check the connections.
Here is a diagram to help you disassemble the unit: http://www.ereplacementparts.com/images/bosch/CCS180K_%283601F6H010%29.pdf
Copy and paste this entire address into your browser and the diagram for CCS180K will open for you. Should your model be the CCS180B, use this address: http://www.ereplacementparts.com/bosch-ccs180b-3601f6h010-18v-litheontrade-612-circular-saw-parts-c-128_1138_15136.html
The battery area is the same for both but, in case you ever need parts, I'll give you both.
Good luck.
Hope this helps. Please place a vote when you accept this solution. Thanks,
Handie Andie
Posted on Aug 22, 2011
Where is the Reset button on Dyson 33 vacuum?
Hi there, it's Jack at Dyson.
DC33 doesn't include a reset button. The motor is equipped with a thermal cutout sensor, which will shut the machine down for protection if something causes it to overheat. This will reset itself automatically once it's been allowed to cool down for at least three hours.
To prevent this from reoccurring we'd recommend washing both filters in cold water without detergent, and checking the machine for blockages. Our online Support guide will walk you through each step: http://www.dyson.co.uk/support/dc33/dc33-multi-floor/my-machine-is-not-working/machine-won-t-switch-on-or-cuts-out/thermal-cut-out
If you'd like some further advice from our experts after giving this a try, please call us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 01, 2014 | Dyson Vacuums
Compressor dosen't restart
replace capacitors might be going off on safety.
Jul 21, 2013 | Dometic Rooftop RV Air Conditioner
92 accord is throwing 1,2,7,and 8 trans codes. Acts up after car warms up, if shut car off most of time won't restart till car cools down
1 and 2 should be your oxygen sensors and 7 is throttle positioning sensor but it could be your coil pack
Jun 04, 2013 | 1992 Honda Accord
Camry overheated and won't start later
with your specs about the plugs / check leads and distributor cap or distributor unit
Aug 17, 2012 | 1997 Toyota Camry
Toyota cuts out when it gets hot
When it won't start check for spark, fuel pressure, injector pulse.
Apr 12, 2012 | Cars & Trucks
My Cub Cadet 2130 has a Kohler Command 12.5 Hp engine. I have had a recent problem where if I shut the engine off after running for a half hour or so it won't restart. Today it died on it's own...
You most likely need to replace the ignition module. You should find it under the shoud next to the flywheel, just follow the spark plug wire.
Sep 18, 2011 | Garden
I have a YTH2454 three years old runs fine for about an hour then shuts off won`t restart until completey cooled down,i have used my leaf blower to clean engine , just today i put new air filter and screen...
the coil that attaches to the spark plug wire may need a replacement for usually when they get old the heat will make them weak after the engine is running causing a problem such as yours here
Jul 04, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Circular saw won't start after having cut pavers
You fried the motor and most of the time it isn't worth repairing, since the parts will cost you more that a replacement saw.
If you are going to continue to cut pavers, suggest you either take it very slow and cut 1 or .5 paver and then let it cool down. But a water cooled tile saw would be better.
Jun 24, 2011 | Saws
My Breadman tr333 gave error message H:E3 and stopped - what does this mean?
This error message means that the bread-maker is too hot. This machine has a cut-off switch and won't start until it cools down sufficiently. Wait a while, then try restarting.
Nov 21, 2010 | Breadman TR333 Bread Maker
Bosch Als 2500 Electric Garden Blower/ Vacuum Logo
37 people viewed this question
Top Bosch Garden Experts
roeb
cwradio73
Are you a Bosch Garden Expert? Answer questions, earn points and help others
