Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
Blades stop working
When mowing the blades stop turning than in 10mins will start again and run for about 10mins then stop again. Belts are all good and tight.
  • 86 Answers
Does your mower have an electric clutch ? If so your problem is most likely a connection
Posted on May 12, 2009
Blades stopped mowing, still runs. What's the issue?
Most likely your belts either came off the pulleys or broke also tension spring may have broken or disconnected ,,with the engine shut off check the main drive area first..then follow back to the deck..if the Belts are in place with the blades engaged check for tension..if none the tension spring or worn belts is the problem..good luck.
Aug 22, 2015 | Garden
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Runs but wil not mowe weels turn when jacked up
There should be two belts one turns the wheels and the other turns the blades.Make sure you have two working belts.It sounds like you need a deck belt,that is the one that drives the blades.
Jul 07, 2011 | Craftsman Garden
When mowing in heavier grass engine loses power. Starts fine and runs fine otherwise.
Raise your deck in high grass, sharpen your blades and turn the throttle up to full speed captain. Check your belts. Good Luck...
Jun 04, 2011 | Garden
Bolens st160 hydro eliminator 16hp tilling transmission .took the blades off 2 sharpen,1ata time,installed them, probably not in exactly the same position.started mowing the mower mows about a foot then...
Make sure the shape edge of the blades is installed closer to the ground. I don't think it matters what the position of the blade is.
Gary
Apr 25, 2011 | Garden
Blades wont engage
check the clutch if it engage then check the cable and belt to if it works make sure all the bolts are tight. usually the belts is too loose or if its a clutch drive maybe the clutch doesn't engage or worn out.
Aug 16, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
May 16, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
340 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
