SOURCE: Brother 8200/8500 Upgrade -- opening machine and replacing motherboard
hi, to open the pc-8200 first you need remove the right cover these have 1 screw under a plastic cap.
now you remove the 2 plastic cover in the left side upper and low these are onlu a screw in the back an remove pull to the left side.
Next remove the plastic cover where rest the embroidery these have two screw, you can see easy...
at this time you have only the front & rear cover, this have a hiden screw and lot of presure grapes.
if you need more help sendme a email [email protected]
SOURCE: can I transfer a pattern from brother 4000d machine to usb
Welcome to Fix Ya!
Are you trying to transfer a built-in pattern from your machine to a USB flash drive? I'm not sure if built-in designs can be transferred in their original form. You might try editing the design a bit, save it to a memory space, then save it to the memory stick. If you have a manual, it should describe how to move designs from your embroidery machine to your computer, and vice versa.
If you are other readers have time to rate my answer, you'll help me become a better expert. If you can give me more specific information about what happens when you try to upload a design from your machine, and whether you have a manual feel free to leave a comment and I'll check back with you.
Cheers, Ginny
Ch
SOURCE: BROTHER PE-8500 EMBROIDERY MACHINE TOUCH
Never mind..I figured it out. Once you get to the number screen, you have to hold down the Start/Stop button while selecting the numbers. I did it 3 times and it worked! Icons are perfect now...Thanks!!!
SOURCE: Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Testimonial: "That was the trick. I knew it had to be something simple but I couldn't figure it out."
SOURCE: brother embroidery machine broken
make sure the bobbin thread is wound and installed correctly
remove tangled thread and clean lint out from under feed plate
clean and remove shuttle to clean out area with lint brush
inspect bobbin for burs and scratches...make sure when reinstalling shuttle and bobbin that it rotates freely
hope this helps
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
ADJUSTMENT
match.
