Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
Jura impressa E80 sends "empty grounds" message
The grounds basket is empty; can't get the error message to turn off
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: My Jura Capresso Impressa S9
This error is due to the coffee sludge built up in the system and needs you open the machine and clean it.
Note - Capresso recommends that you unplug the unit, wait a minute, and then plug in and turn on. Try twice if the first time doesn't work. If you still have a problem, call Capresso, and if your machine is under warranty they will repair it for you free of charge and even pay shipping both ways.
For cleaning instructions, let me provide you with a generic link that would help you :
http://www.buessert.de/Technik/Jura-IMPRESSA-S95/Cleaning.htm
Good Luck!!
Thanks!!
Posted on Aug 19, 2010
wentlanv
  • 710 Answers
SOURCE: My Jura Impressa E80 keeps
Hi JM,
Sounds like you have a stuck valve or a blockage. First you can try pressing the "draw off" button and releasing some of the liquid.
If that does not solve the problem permanently, then send it in for repair. If you wish to do repairs yourself, here is a website that describes the disassembly of the Jura coffeemakers. The one described is not your particular model, but I believe it is close enough for you to know what to do. In order to disassemble, you need a set of Torx screwdrivers.
Here is the web address: http://www.buessert.de/Technik/Jura-IMPRESSA-S95/Reinigungsanleitung.htm
Copy and paste this into your web browser. There are a few things in German, but keep scrolling. It is in English.
Hope this helps. If it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Jun 06, 2011
Jura z7 error message empty coffee tray when tray s not full
Yo James,
I know nothing of your unit, but I've never let that stop me before??.
Sounds like a sensor is stuck in the "tray full" position and popping an error message based upon what "it" is detecting.
OK, how does the unit know from "full tray" (what ever that means). I'm a big believer in problems being created by dirt, crud and in your case, coffee grounds. Unless the sensor (switch?) itself has failed, I'll bet there is debris fouling the system.
Find the "full tray" (what ever that means ??) sensing mechanism and clean/replace it and I'll bet you will solve the problem.
All the best.
Dec 07, 2014 | Jura Impressa Z7 One-Touch Automatic...
Why empty grounds message stays
So did you empty the grounds?
Pull the plug and plug it back in.
There is an encoder disk that spins around to control the mechanical movements inside the unit. Some mechanical piece is not where it is supposed to be and the circuit board it waiting for a sensor to clear. Cycling the power will normally make all the mechanics reset to the start position and clears errors/jams etc.
Sep 08, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura impressa s9 is displaying error 1
The Owner Manual for the Jura Impressa S9 One Touch identifies Error 2 as being too cold and disabled for safety, but simply instructs to "Turn the IMPRESSA off at the power switch. Contact Customer Support in your country." for all other errors.
See Online Manual: http://content.costco.com/images/Content/Misc/PDF/OwnerManual-671992.pdf
Apr 29, 2013 | Jura Impressa S9 One Touch
Cannot install tray with ground basket installed, after removing. Mechanism is blocking the ground basket when the tray is slid back into the unit after emptying.
Try putting a container under the coffee spouts and pressing the rinse button. This will usually free any coffee grounds that may not have been expelled into the grounds basket from the last time the machine was used. The grounds can get stuck and block the slide path of the grounds basket.
Dec 23, 2010 | Jura Capresso Jura / Capresso IMPRESSA J5...
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
Aug 15, 2010 | Jura Capresso Impressa S8 Coffee Maker,...
Jura f70 error 8 solution
There is a Jura Error Guide that says:
  • Turn machine off, turn the main power switch off and unplug machine for at least one minute.
  • Turn machine on again. If the error message comes up again, try one more time.
Dec 31, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Open tap - filling system - close tap
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Jul 10, 2009 | Jura Capresso Impressa E75 Espresso &...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
61 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
