Question about JVC TH-M606 System
Sound output how do I my tv to work with my surround sound. I got all the cables hooked up but nothing is happening.
2 Suggested Answers
  • 93 Answers
SOURCE: i need a diagram of how to hook up my jvc 5.1
I my self don't have that exact unit, but most are similar, and i have looked up the specifications which are:
Inputs:
1 x S-video input
1 x Composite Video Inputs
1 x Digital Audio (TOSLINK) Input
1 x Stereo Audio Input
Outputs:
document.write(neg_specification_newline('1 x S-Video Output
1 x HDMI Output')1 x S-Video Output
1 x HDMI Output
INPUTS (coming from devices to the system):
1) The unit already comes with a DVD player, correct? If so you don't need to connect it. If you do, connect your DVD play via an s-video input, since a normal DVD player doesn't need a higher quality/resolution input.
2) Connect your cable box to the home theater system via a composite cable (the one with Red green blue), if it has composite outputs ofcourse. If not, do it visa versa with the DVD, if your dvd has composite. So make the dvd via composite and cable box via s-video.
3) Audio from the dvd, this would be via Digital Audio (TOSLINK) Input or stereo audio input. the digial audio will give you true 5.1 surround sound, and the stereo will only give you left and right channels, like you would hear from anything else (like a normal cd, radio, etc).
4) audio from cable box, would be again depending what you want. If you cable provider gives you alot of programming that has 5.1 surround sound (mostly HD channels), you would be better off with the digital audio. But if you watch more via your DVD, then connect the cable box via the stereo input. Again, this is to your preference, and which one you want true 5.1 surround sound from. The system should be able to 'emulate' 5.1 surround sound via the stereo cable too, but if your watching a movie, it can't really tell if a sound is supposed to come from the left rear or the left front.
Output:
5)connect to tv via HDMI if available, or S-video.
HDMI is much higher resolution (HD quality) S-video is normal cable programing or 'dvd quality'.
And the Tv would be left on mute or volume=0 since no audio is connected to the tv! All the audio should now come from your system.
Sorry if this was too vauge, but I don't have the same system and dont know exactly what/where all the connections are. If you have any other questions let me know.
Posted on Feb 27, 2009
We have a new TV, old surround sound, old dvd player & want to get Blu-ray player with component video output to work with our surround sound. Is this possible & Which Blu-ray player?
component video output is not going to help you hook it up to a surround system. component video is just that - video. No audio signal is carried on it. You would be better served hooking your blu-ray player to the tv via hdmi cable and then running an optical cable from either your blu-ray player or your tv to the surround system (assuming your surround system has an optical input).
Dec 24, 2016 | Televison & Video
Hook mz506 surround sound to my Samsung tv
Typically surround sound is run through a receiver or stereo. The sound from the tv is carried to the receiver by cables (hdmi or Audio-Video connected to input area of receiver). Then the speakers are connected to the output area of the receiver.
If you are not using a receiver, then the speakers must be able to connect directly to the tv and you have to see what kind of cabling your tv supports.
Jan 27, 2015 | Logitech X-540 Multimedia Surround Sound...
I want surround sound. How do I hook up my audio 5.1 RVC-884VBK, with my HDbox and LCD TV? It's too confusing. What hooks to what? Currently the HD box and blueray DVD is hooked straight to TV ...
Does you television have an "Optical Audio Output"? This would be the best and easiest way to get surround sound from your system. If your TV has an optical output the you can use an Optical Cable to connect the TV to the reciver. This way whatever you are watching from the TV will be in surround sound. The HDMI connection sends a surround sound signal from each device to the television. If you connect it to this output on the TV then make sure the optical output is turned on in you telivison's menu. If your TV does not have an Optical Audio Output then you will need to connect each optical output from the blu-ray and HDbox to your reciever. Your reciever will need to have two Input channels(one for each device). Then you can select that input to the device(blu-ray or HDbox) that you are using. The optical cable is the best way to go for surround sound because it is pure digital and produces the best sound. If the HDbox or Blu-Ray does not have an optical output then you will need the six rca jacks to get the surround sound. Let me know further info on what you have so I can assist you more.
Jun 26, 2010 | JVC RX-884V Receiver
Audio output on TV
Sounds like you have it hooked up properly. Be aware that if there is not a digitally encoded signal for surround sound [they don't always do that] you simply won't have surround sound. Usually there is a mode in your receiver/amplifier that will allow you to simulate surround sound. An example of that would be "theater" or "hall" sound. Try it with a DVD known to have surround sound encoding [most of them do] and see if it works that way. If it doesn't then check your owners manual for information about how to make sure that feature is actually turned "on".
Apr 16, 2010 | iLO Televison & Video
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
Hooking up new tv to surround sound
I recently purchased a vizio 37" LCD tv, I have tried everything in hooking up my Sony DVD surround system to the TV. However, I found no audio output on this TV. Could you tell me if there is a way to hook the tv directly up to the surround without an output?
Is there something else I need to buy?
Feb 17, 2008 | Vizio VX32L Television
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
JVC TH-M606 System Logo
20 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
