Question about Health & Beauty
The toothbrust doesn't work even with good batteries.does the mechanism have a problem?for colgate 360 whole mouth clean
Will i loose my teeth if constantly having bleeding gums?
Visit a dentist and a doctor as there are worse things than gum disease in the mouth
Mar 23, 2017 | Cars & Trucks
What are the popular brands of manual toothbrushes?
The two most popular brands of manual toothbrushes are Oral-B and Colgate. These companies pretty much control the market when it comes to manual toothbrushes. You can learn about their different manual toothbrushes at these websites: http://www.oralb.com/products/manual-toothbrushes/ and http://www.colgate.com/app/CP/US/EN/OC/Products/Toothbrushes.cvsp.
Feb 04, 2013 | Health & Beauty
Cannot hear my voice when somebody calls me
are you referring to a phone? If yes, it means the mouth piece (mic) of the phone is defective or maybe dust or an object is blocking the mouth piece hole.
You need to disassemble the phone and clean the mouth piece part. And if that doesn't help, replace the mouth piece.
Or you can use handsfree (earphone) with the phone pending the time you fix the mouth piece problem.
Regards.
Sep 20, 2011 | Cameras
I have OverG Fighters (XBox 360)... even though I successfully complete mission 1 in Area 1 (ie US) and save it... the game won't move on to the second mission, it just keeps repeating mission 1...
Most likely it is one of two things-
1) Your disc has dirt or scratches on its surface causing the next mission to be unaccessible. Try to remove your disc and clean it off with a wet cloth. If there is no noticeable damage the proceed try again.
2) It could also be a reading error with the Xbox laser. Shut down the system and try to blow some dust out of the Xbox using compressed air if you have it, otherwise just blow through your mouth.
Judging by your description im guessing its a disc error, clean it the best you can, if it still doesn't work take the game to a game store to have it cleaned professionally.
Lastly, before taking it to a store try and delete your saved data and start a new game, it is possible your data is corrupted, this may fix it as well.
I hope this helps a bit!
May 16, 2011 | Ubi Soft Entertainment Over G Fighters for...
Hi my name is adin and my viva pinata disk is not working I have tryed peanut butter and colgate on the disk but it wont work.
Dont Try The Colgate Or Peanut Butter Trick Its Not Real You Can Buy A New One For Cheap ( Maybe £4.99)
Nov 25, 2009 | Video Game Consoles & Games
"Disk is unreadable"
Since CDs and CD-R's work fine, its probably that the disc tray of your xbox 360 is not working. you might wanna try contacting xbox customer support to check the warranty status of your console. might as well send it in for repairs
Mar 23, 2009 | Microsoft Xbox 360 Elite Console - Black
Xbox cant read disc
check and see if the disk is scratched. if there are scratches, follow these directions:
take your game disk and with Colgate (preferred) toothpaste (not gel, use the white thick stuff).
squeeze a small amount of toothpaste unto the disk's reflective surface (part with scratches) and smooth it on in a circular motion, applying more when necessary. you want to have it on at least a little bit thick, so it covers the whole surface. leave the toothpaste on for about 5 minutes and then rinse it with lukewarm water, making sure all the toothpaste is off. You will likely still notice a few scratches but most will have disappeared.
stick your disk back into your 360 and load the game. with any luck it will load! =)
if this doesn't work, contact xbox customer support at 1-800-4MY-XBOX
Dec 25, 2007 | Microsoft Xbox 360 Console
Health & Beauty Logo
89 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
