Question about Garden
WHAT KIND OF GREASE OR OILDO I PUT IN THE GEAR BOX
  • 181 Answers
It depends on what type of machine you have.let me know what machine you have and i'll be glad to help you out.....
Posted on May 12, 2009
How much grease to put in gear box on a honed fg100
If it is heavy grease and not a 90 weight or better gear oil, you can pack it full. Use solvent and pressure to get all the old stuff out.
Oct 06, 2013 | Honda 25cc 4-cycle Mini Tiller
Tip
My mixer is leaking oil.
This kind of unit are lubricated with grease paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
The oil leak is usually coming from the gear box inside the appliance.
To fix the problem the unit must be taken apart, and cleaned. After this step, there is need to spread again the grease, using special foodsafe grease paste.
Disassemblying the gear box is not that easy, you will need previous experience and a gear puller to do the job properly and safely.
This appliances are also held with security screws to prevent the users from taking apart the unit, and can only be disassembled using a Security screwdriver tip.
The grease can be purchased here, check at the bottom of the page: Kenwood chef food mixer Grease.
on May 28, 2009 | Kenwood KM300 Chef Stand Mixer
What kind of grease for a dewalt table saw?
Hi, Dewalt is always expensive (actualy their owned by Black & Decker)
but what you need to get is a grease that has a high tempreture rating as it is for inside the geers, this is to avoid the grease drying out and going hard , go to a local Irnmonger and he should be able to advise you,or talk to a mechanic as they know about oils and grease...T.C.
Mar 19, 2013 | Saws
It has been bitterly cold the last few days, but the transmission won't come out of 1st gear when you start it. It is a manual 1.6L. We just bought it off of craigslist, and Im wondering if the...
put a large spot lite or some kind of lite next to the gear box for a day or so, once it starts to shift drive it for a good while drain trans put in a lighter weight grease that wont jell
Feb 25, 2011 | Geo Tracker Cars & Trucks
My K45SS is leaking some kind of oil or grease from the part of the mixer above where the mixer part attaches. It otherwise seems to be functioning fine.
its gear oil from the gear box that the motor turns to make the beaters turn,you need to replace the seals or keep adding food grade oil before you dry out the gearbox and ruin it
Mar 09, 2010 | KitchenAid K45SS Classic Stand Mixer
Mine is a Chef Stand Mixer but really don't know model no. Where to find?
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause leaks.
To lubricate the unit, you need to spread again the grease in the gearbox, using special foodsafe grease paste.
May 26, 2009 | Kenwood KM300 Chef Stand Mixer
Hobart D300T mixer oil change.
Call your local hobart branch and tell them you need grease for a d300 mixer.Yes this mixer uses grease now.If it's older they used oil but is no longer available.
Mar 15, 2009 | Hobart D300 Stand Mixer
Oil leaked from Kenmore mixer- model mumber 201
This kind of unit are lubricated with grase paste. If the unit stays inactive for a long time, or if the motor and gears are overheating the grease paste gets melted into thin oil, and that will cause the leak.
Nov 18, 2008 | Kenmore KSM100 Stand Mixer
Oil leaking
Sep 30, 2008 | Spar SP200 Commercial Planetary Stand...
A200T mixer
On the bottom of the planitary the part where you put the beater. there is two nuts. one lookes like a Acorn nut and a thin one above it. By the book the top thin one should be finger tight. Not wrench tight. you need a thin wall 3/4" wrench you hold the thin nut with iot and tighten up the bottom acorn up to the thin one and they lack against each other so not to come losse .on some mixers this thin nut tightend down will mess with older parts and bind the centersahft parts.
Aug 14, 2008 | Hobart A200 Stand Mixer
Garden Logo
147 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
