Question about iLO DVDR04
Replacing DVD drive on R04
I had the problem where my recorder kept "preparing" the discs and ruining them. From searching around on the internet, I thought I needed a new drive. I purchased a Liteon 411 (used-- since they are no longer made), plugged the new drive in with the two connectors in the back (the ribbon one and power source connector), and now all I get on the DVD player is "hello". It won't go to the main screen or anything. Did I not install the new drive properly, do I have a bad replacement drive, or is the problem bigger than that?
  • 44 Answers
Could be you have been double-crossed by the used drive. Installation is pretty easy as the data and power cables are both keyed (check the pins on the drives data cable connector to make sure they are not bent). Only other thing I can suggest on the replacement drive is to make sure it set to "MASTER".
I suppose you could try another drive just to confirm that the issue is in the replacement. WalMart sells an internal 22x LITEON DVD Writer for $39, Bar Code 44149 00406 (others may not be IDE) that you can test or permanently repair with.
To test, unplug your ilo and simply:
1.Setthe new 22x drive to MASTER (comes set as slave out of box, see theirdocumentation or the drives cover switch legend markings).
Note: If you want to test using a pre-recorded commercial DVD you will need to do step 2 and first install it in a PC. You can, however, test a blank DVD+R at this point by just connecting the cables.
2. If you wish to play commercial DVD's in your ilo, you must first install this DVD writer in a PCand play part of a studio recorded commercial DVD. This will set the units Region Code.If you don't do this, the drive will not play commercial DVD's (it willnot start or it will lock after copyright screens). If you don't wishto play commercial DVD's in your player, you don't have to do thisstep... it will play DVD's it creates just fine without it.
3. Take off the top of the ilo and move the flat data cable and the power connector to the new 22x drive.
4.Re-test all your issues. If your problems go away then you need the newdrive. If not, the only other user action I can think of short ofmaking sure all the cables are tight is to reload the firmware(http://www.ilohelp.com./download2.htm) but that assumes you can get past "hello" which sounds like you may not be able to do.
The new 22x drive can be installed in the ilo and, with some work,look just like the original from the outside. Some other posts also sayyou can open a hole in the top or back cover for the cables to exit andjust leave the new drive on top of the ilo. Not crazy about that optionbut up to you.
Hope this helps. Good luck!
Posted on Jul 21, 2009
DVD Recorder door sticks and the disc preparation process does not complete
Try to burn at the lowest speed possible or at one step lower speed that the one you are currently burning at.
Dec 27, 2013 | Dual Presidian DVD Recorder
We have a govideo vr2940 and the dvd recorder does not copy vhs to dvd. the machine wont read the disk. we tried different types of blank dvd's but still says no disk. i found a solution that says...
I've had this problem (No disc) with my VR2940 and was preparing to open it up and find and clean the lens that detects the disc. This was suggested as a solution.
However, I used a can of compressed air (enviro-duster) and sprayed air in the drive slot (back and forth since I don't know where the lens is located).
No problem since, but I keep a can handy.
Norm
Apr 03, 2011 | GoVideo VR2940 DVD Recorder/VCR
Won't record on DVD+R discs.
These ilo R04 only record on 4x speed or slower, the new 8x or 16x won't work or will damage laser.The new variable speed discs work,these say 1x-16x.
Some brands of discs won't work in Ilo's.Try name brands disc like Sony, cheap brands often won't work.
Have you cleaned laser use commercial disc cleaner?Laser can be manually cleaned with a Qtip soaked in rubbing alcohol but this requires opening dvd burner.If you do this make sure electrical plug is pulled, laser will cause serious burns if you remove top while still plugged in.
Jul 27, 2009 | iLO DVDR04
Only view in black and white on my ilo DVD R04
I was having the same problem. My DVDR04 was working fine. And after about four months of not using it I desired to use it. Turned it on and everything was in black in white. After searching on line and e-mailing Ilo which I never got an answer. I finally tried using an RCA video (Yellow) cable on the line out video jacks, replacing the line out S-Video jack/cable and it worked fine back in color right away.
May 11, 2009 | iLO DVDR04
Dvd disc recorded on dvd recorder wont play on any other dvd players
make sure you have 'finalized' the disc.. this prepares the DVD in a special way to be used on other players... without finalization the disc is almost just like an extra disc drive and you can continue adding material until it is full
'Finalize Disc' will be a menu option in your writing software but it may be called something else but whatever it is there should be a little explanation attached to it explaining that it is to 'finish' the disc for use on another player
Oct 20, 2008 | Televison & Video
Presidian 3222
I don't know if this will help, but according to the operator's manual I have, on page 64, the only place it mentions "Full" or "Quick" Preparation, is when using a DVD-RW disc. Apparently, with this type of disc, you must use the Full or Quick preparation INSTEAD of Finalizing after you're thru recording onto the disc.
With the DVD-R and DVD+R, all you can do is "Finalize"; With the DVD+RW, if I'm reading this correctly, NIETHER Finalization OR Preparation is required.
But with the DVD-RW, apparently ALL you can do is a "FULL" or "QUICK Preparation.
If you're only getting "Erase or "Finalize" WITH the DVD-RW, then it appears there may be a problem with the machine.
Or, if you're attempting the "FULL or QUICK" Preparation with any disc OTHER than the DVD-RW, all you should get is "erase" or Finalize", since the QUICK or FULL Preparation is not done with discs other than DVD-RWs.
Hope this helps. I'm certainly not an expert on these things....I'm a "Vinyl" type guy.
Roy Davis
May 31, 2008 | Dual Presidian DVD Recorder
I purchased the DVDRo4 and its been pretty reliable so far.
These R04 are fickle,some Brands of DVD discs won't work in ILO,try another brand.Also clean laser in iLO it may be dirty,use commercial cleaning disc,put a drop of rubbing alcohol on brushes.Do not use any other chemical.
It is possible you laser is defective or starting to go.If that's the case you need to replace burner/loader.
Some dvd recorders formulate a little differently,I have made recordings in my iLo that won't work in all brands of players/recorders.
Aug 14, 2007 | iLO DVDR04
LVW-5005X DVD Recorder setup tv tuner
You have the wrong firmware,or cd is corrupted.These Liteon recorders have had some issues with the timers.The 5005xa can actually be transformed into the Ilo R04.Look on internet the Wizard has free firmware for your unit, look for iLO R04 which is almost identical to your unit.
If the remote is broke they are easy to replace ,if the recorder is a 5005xa the remote is a clone to ones used in the iLO RO4,used ones can be bought on Ebay for $10 to $20.If it is 5005XSA use the Liteon Rm 51 remote.The Gateway AR 230 recorder and some of the Akai remotes are clones to the Liteon5005XSA remotes.
Jul 10, 2007 | Lite On LVW-5005X DVD Recorder
iLO DVDR04 Logo
328 people viewed this question
Top iLO Televison & Video Experts
AFcityboy
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Radames Pagan
Radames Pagan
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
