Question about Bpi USB Ethernet Adapter - PC and MAC Compatible (BUE1U) Network Adapter
Driver Bpi USB Ethernet Adapter - PC and MAC Compatible (BUE1U) Network Adapter
Usb to ethernet adapter for mac or pc not working
A common problem with this piece of equipment is that most people don't know that the drivers are actually in the device itself. When you plug it in, it should show up in "My Computer" as a letter device. Open up that folder and search for the driver which corresponds to the operating system you are running. If you have a Mac, is should be similar in appearance, but just a drive icon on your desktop. Good luck.
Mar 05, 2014 | Gigaware USB Ethernet Adapter
Tip
I think there are 6 ways (at least?) to connect this printer: (1) Direct to Mac...
(1) Direct to Mac (or PC) via USB Cable (2) Direct to Mac (or PC) via Ethernet Crossover Cable(3) Ethernet to router/switch, with Mac/PC also via Ethernet to router/switch(4) Ethernet to router/switch, with Mac/PC via WiFi (802.11 wireless)(5) WiFi to router, with Mac/PC via Ethernet to router/switch(6) WiFi to router, with Mac/PC also via WiFi.
As (1) should be simplest, tried this first. First document would print instantly and completely, next doc would hang in queue with unexpected msg, "Printer is offline." Only way to print 2nd doc was to power cycle (off-on) the printer. This problem occurred whether 2nd doc was sent to printer before or after 1st doc had printed. Tried 2nd USB cable, tried new driver, tried reinstalling printer; same problem. Spoke to both Samsung and Apple support, including both on a conference call; never got this to work and never clarified if problem was in printer hardware/software, driver, or something else. Both companies now showing this issue as unresolved.
Nothwithstanding USB problem, did succeed in modes (4) and (6), although custom wireless config needed since my network does not broadcast SSID and requires an encryption password. Procedure required connecting first via Ethernet, obtaining Configuration Report by holding down orange button for 5 seconds, then using browser to connect to the printer's IP address. Also required different driver for wireless config (as opposed to USB).
Bottom line: What seemed simple - USB direct connect - proved unworkable, but wired and wireless network config works fine.
on Apr 25, 2010 | Office Equipment & Supplies
What is the difference between USB Ethernet Extender and a USB Ethernet Adapter?
Extender boost your wireless connection range.
Adapter is use to connect to a wirelles connection (router)
So let say you have a router far from your PC the extender boost your adapter range to get the router best signal
Jun 07, 2013 | Computers & Internet
F5d5050 Belkin USB 10/100 Ethernet Adaptor - Does it work with Windows 7 64 bit OS? I have spent hours trying to install a Swann and a Digitech product but none seem to work with the above OS. Any...
You cannot install this adapter in a Win 7 computer because the drivers are not compatible with Win 7.
So far Belkin haven't updated the drivers for win 7 OS. The latest drivers for this adapter is compatible only with
" Windows 98SE, Windows Me, Windows 2000, Windows XP 32-bit, Windows Vista 32-bit "
Click here to see the belkin compatible drivers in the website.
With Regards,
Prema.
Jan 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
Looking for a MAC driver for my F7D4101. The F7D8302 allows MACs to access it, so I bought it's little brother, the F7D4101, thinking I wouldn't have any issues. I need this to work with my MAC, please...
You are trying to install F7D4101 in your mac computer , which is not possible because its not compatible with Mac computers
There is no drivers for the Mac OS for this F7D4101 wireless adapter , its compatible only with Windows XP, Windows Vista, Windows 7
Thanks & Regards,
Prema
Dec 31, 2010 | Belkin Play Wireless USB Adapter (F7D4101)
My dell pc can't activate the connection
try to use a 3com lancard it is the most compatible lancard for dell i hope this will help
Sep 17, 2009 | Dell Ethernet Card Network Adapter
USB 2.0 to RJ-45 LAN Ethernet Network Adapter driver required
SMC2206USB/ETH Drivers
SMC2208USB_ETH Driver
SMC2209USB/ETH Drivers
If it's an SMC with a little luck you'll find the drivers for your specific model number, Otherwise, go to SMC Site and search for your model number. If it's not an SMC device, let me know what brand and model number it is.
Alex
Mar 25, 2009 | SMC USB 10/100 m Ethernet Lan Card Adapter...
Apple computer compatable
No it's not.
Ativa's web page (here) does not offer a driver for Mac.
"What operating system does this device support?
This device support Windows 98se, ME, 2000, and XP. It is not compatible with Mac systems."
Sorry, but you might have to look for an appropriate AirPort card.
Sep 30, 2008 | Office Depot Ativa Wireless-G USB Network...
Drivers for Ethernet Controllers & PCI Modem
Go to the manufacturer site and search for driver. USB network driver is not compatible with XP, then you have to download latest driver from site. you can try here www.packardbell.com
or original manufacutere of it
you may give correct details about usb network adapter
Apr 15, 2008 | Linksys PCMCIA Network Card PCMPC100...
Bpi USB Ethernet Adapter - PC and MAC Compatible (BUE1U) Network Adapter Logo
324 people viewed this question
Top Bpi Computers & Internet Experts
David Payne
David Payne
Are you a Bpi Computer and Internet Expert? Answer questions, earn points and help others
