Question about Denon DRA-685 Receiver
Screen has light on but iniput - vcr always on
Approximately one week ago the screen lite up and has stayed lite
with no volume sound and none of the buttons working. Is it fixable.
Lou Marcel:
  • Denon Master
  • 19,396 Answers
Re: "screen lite up and has stayed lite with no volume sound and none of the buttons working".
That means that the unit is on fault mode (protection).
Try unplugging the speakers, and leaving unit unplugged from power for one hour, then plug in a new set of speakers(check impedance of speakers is in range first).
If the unit does not restart doing the above, then it must be disassembled, tested with a multimeter and fixed by an experienced person.
Do not forget to let me know if unplugging (hard reset) and replacing speakers (speakers shorting inside can cause same) solve your problem. In that case do not forget to leave feedback.
Many thanks.
Posted on May 07, 2009
Ds light green,dim green, amber then off when power is turned on
Sounds like you need to send it in for repair. I had sent my console to VideoGame911.com and they repaired mine at a great cost and got it back at the end of the week. Give them a try, they are cheaper than a manufacturer. Good luck!
May 04, 2013 | Nintendo DS Lite
My sound up and lock button are sort of switched on my ipod touch...for example: i press either key if pressed it will turn the volume will turn up one point and then lock..if held it will turn up the...
The volume is messed up from the jailbreak. To un-jailbreak it, plug it in, and go to itunes and restore the Ipod touch. Careful, as this will DELETE everything on the Ipod, but its the only way to fix this and any other jailbreak issues. You can always go back and reinstall everything after you have restored the Ipod.
Oct 17, 2010 | Apple iPod touch
No data is sent to the screen
When the screen goes completely black, shine a very bright flashlight closely at the screen. If you can see the image, then the most likely problem is that the backlight inverter has failed.
The inverter is a circuit board that works like a flourescent light ballast. If the inverter fails, there is no backlight, and the screen is black.
Since the invertor is a high-voltage component, I would also listen for any unusual sounds associated with the failure: e.g. buzzing, whistling, popping.
To rule out some sort of connection failure, see if you can recreate the failure mode when using the TVs internal setup menu. The setup menu does not rely on any external inputs....of course neither does the volume control or channel indicator on the screen.
Oct 07, 2009 | Philips 32PF7320A 32 in. LCD Television
Just goes to black screen
It under mfc warranty contact dealer you purchased it from for repair or exchange.
Aug 29, 2009 | Vizio L37 Television
There is no sound in my ds lite. all do it makes
why don't have that checked somewhere or you could always get replaced if its under warranty.
Jul 15, 2009 | Nintendo DS Lite Console
Works on occasion.
I believe this set has two relays in the power supply. One for standby power and one for full power. I have seen cases where the full power relay drops out or not energise causing the same symptom you describe. Lightly tapping on the relay sometimes identifies the culprit.
Hope this helps
Skyassoc
Jun 20, 2009 | Hitachi 53UDX10B 53" Rear Projection...
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Nintendo DS Lite Touch Screen Fades
You're going to have to send it in for repair. It sounds like it's out of warranty, which is unfortunate.
Dec 05, 2007 | Nintendo DS Console
Remote volume control for Sharp Aquos 42inch LCD not working
ok please open the remote then clean it with pencil eraser.
Oct 09, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Denon DRA-685 Receiver Logo
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
