Question about GE AJCH10ACB Built-In Room Air Cool Unit
Air Conditioner unit won't switch on outdoors
The air conditioner is a split system unit. The inside unit switches on for about 15 seconds but there is no air and then it switches itself off. The outdoor unit, fan is not working. I have relaced batteries in the remote and it works but still no air or fan movement.
  • 1,420 Answers
Re: Air Conditioner unit won't switch on outdoors
Can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
Plz u tell me ?
indoor moter was not moving or outrdor plz tell me?can i solv your question plz hary up
Posted on Apr 10, 2009
0 characters
3 Points
I have a split-type aircon (brand: LG) with remote control.It has power and display when i put on batteries. but the aircon unit does not respond to the remote control. what do i do to fix this?...
Lift the front cover of the air con, on the right hand side there is a button or a hole which has a button inside which you can press which is for manual starting of the air con. If this works, then you will know the remote is faulty, if it still doesn't work, check that the isolator switch for the air con hasn't been turned off. There will be 9Or should be) a switch outside next to the air con outdoor unit to switch power on / off to the air con. If not, there should be switch inside the meter box at the front of the house. Make sure they are switched on.
Apr 06, 2016 | LG LSC121PMA Split System Air Conditioner
How to check MSG12HRN1W MINI SPLIT SYSTEM electronic board
If your mini split was installed to meet most building codes, an inside disconnect switch should have been installed. This switch breaks the power and signal from the outdoor unit to the indoor unit. It is not the same as the outside disconnect to the compressor (outdoor unit). If it was turned off, the inside unit would be dead. Look for a disconnect switch inside your room. By code is should be within 15 feet of the inside unit.
Nov 04, 2014 | Air Conditioners
No power to my aleegiance 15
If you are not receiving power to the outdoor unit a few things to check would be the circuit breaker, the outdoor fuse box, and the connections to the control panel inside the air conditioner . Also, if the unit is equipped with high and low pressure switches this could prevent the unit from operating if the switches are open.
May 27, 2014 | American Standard Allegiance 15 4a7a5036e...
Conditioner Fan
this a split system? inside and outside unit? possible relay( if it has one) or contactor. make sure 230 volts at contactor.
Feb 19, 2014 | AmcorAire UCHW-H24AF2 Split System Air...
When calling for heat the outdoor unit fan cuts off and the compressor stays running after about forty seconds.
Actually, for heating mode, the condenser fan works on pressure build up by Fan pressure Switch. If pressure less the fan won't run.
Dec 08, 2010 | LG Art Cool LA181CNW Split System Air...
I have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Jun 25, 2009 | LG LSC091PMA Split System Air Conditioner
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
AC not working
Try opening the front of the machine and check the circuit board has not got anything on it the could cause a short. I had the same problem but mine was a gekko that fried on my circuit board.
Sep 25, 2008 | Fujitsu 12C1 Air Conditioner
Evaporator unit turns on for about 15 seconds then turns off
Out of range thermistor can cause the tripping of indoor or outdoor unit. Try to check the resistance of your thermistor it should be 8 to 10 kilo ohms at 25 deg. c temp.
Oct 31, 2007 | LG LSC121PMA Split System Air Conditioner
GE AJCH10ACB Built-In Room Air Cool Unit Logo
501 people viewed this question
Top GE Air Conditioners Experts
Lawrence Oravetz
Are you a GE Air Conditioner Expert? Answer questions, earn points and help others
