Question about B Dazzle B. Dazzle Scramble Square "classic Motorcycles"
Scramble Squares Puzzle solutions
Tropical fish
What is tropical cyclone
Tropical cyclone - Wikipedia
https://en.wikipedia.org/wiki/Tropical_cyclone
A tropical cyclone is a rapidly rotating storm system characterized by a low-pressure center, a closed low-level atmospheric circulation, strong winds, and a spiral arrangement of thunderstorms that produce heavy rain. ... Tropical cyclones typically form over large bodies of relatively warm water. ‎Tropical cyclone scales · ‎Tropical cyclone naming · ‎Tropical cyclone warnings
What is a Hurricane, Typhoon, or Tropical Cyclone? ' Precipitation ...
https://pmm.nasa.gov/education/articles/what-hurricane-typhoon-or-tropical-cyclone Teaches about what a tropical cyclone is, and how "Hurricane", "Typhoon", and "Cyclone" are all different words for the same phenomena.This website, presented by NASA's Global Precipitation Measurement (GPM) mission, provides students and educators with resources to learn about Earth's water cycle, weather and ...
About Tropical Cyclones - Bureau of Meteorology
www.bom.gov.au > Tropical Cyclones Australian region tropical cyclone warnings, forecasts, seasonal outlooks, cyclone history, climatology and related information.
A cyclone - NOAA's National Ocean Service
https://oceanservice.noaa.gov/facts/cyclone.html Feb 2, 2018 - A tropical cyclone is a generic term used by meteorologists to describe a rotating, organized system of clouds and thunderstorms that originates over tropical or subtropical waters and has closed, low-level circulation. The weakest tropical cyclones are called tropical depressions.
tropical cyclone ' Definition, Causes, Formation, and Effects ...
https://www.britannica.com/science/tropical-cyclone Tropical cyclone, also called typhoon or hurricane, an intense circular storm that originates over warm tropical oceans and is characterized by low atmospheric pressure, high winds, and heavy rain.
Apr 22, 2018 | Vacuums
Cloudy water that stinks
1st priory is to save the fish !! move them to a new container consisting of half old water and half new water (declorinated) along with a small air bubbler !! this should help your fish to recover (don't use soap to clean out container it is toxic to fish) moist table salt is best to use for a cleaning agent and rinse well b4 putting fish inside
then ck to see if your aquarium is pumping water thru the filter and falling back into tank ( replace all the water in the tank 1st with two rinses ) make needed repairs to pump and or filter assembly (New filter cartridge) new pump impellers and cartridges are available for purchase for your aquarium from vendors that sell aquariums and allways ck the outlet the pump is plugging in b4 blaming a pump fail with a known good table light set to "On" they do go off once and an a while
verify that water chemistry is ok b4 retuning fish to tank and observe fish for strange behavior for next several hours ( upside down swimming, laying sideways )
Jan 02, 2014 | Marineland Filtration Eclipse Seamless...
Do I need an aquarium chiller for tropical fish?
Tropical fish do not require cold water to survive; however the water temperature should never go above 30 degrees Celsius, or you could kill your fish.
Aug 29, 2012 | 1topstore Fish
Why do salt water aquariums need heating and cooling units?
Most saltwater aquariums are generally used to housetropical fish. Tropical fish are fromthe Tropics (the area of the planet around the equator.) The water temperature varies in differentlatitudes and depths, but it tends to stay between 77-80F (about25-27C). Therefore, you want to houseyour fish in the environment that is most like the one they are accustomed to,if you want them to stay healthy. Therefore, maintaining aquarium temperature with heating and coolingunits is essential.
May 13, 2012 | Fish
Answer to puzzle 100 please
This continues to be the most commonly asked about Curious Village puzzle on FixYa (with a quick search revealing several pages of answers)
As the hints state, all but one square is tilted and each pin can only be used once
The hints also give you the location of three squares and tell you the size and angle of another two squares
As an extra hint, none of the three small tilted squares mentioned in the hints overlap each other (knowing this gives you the location of one more square and just two possible locations for another)
From here, the rest should be easy (with eight pins to form two squares)
Make sure to use all the pins (all squares must have a pin in each corner)
A picture of the solution can be seen here if you need it
http://professorlaytonwalkthrough.blogspot.com/2008/02/puzzle100.html
Dec 16, 2010 | Nintendo Professor Layton & the Curious...
The seven squares puzzle in the curious village
This continues to be the most commonly asked about Curious Village puzzle on FixYa (a quick search reveals several pages of solutions for this question and two of the last six questions have asked this)
Nov 07, 2010 | Nintendo Professor Layton & the Curious...
Solving puzzle 100 on professor layton curious village
This continues to be the most commonly asked about Curious Village puzzle on FixYa (a quick search finds several pages of answers)
Jun 06, 2010 | Nintendo Professor Layton & the Curious...
B Dazzle B. Dazzle Scramble Square "classic Motorcycles" Logo
111 people viewed this question
Top B Dazzle Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a B Dazzle Toy Expert? Answer questions, earn points and help others
