Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Bissell Cleanwell II Bagless uprighht vacuum
While using the vacuum, it begins to smell like burning rubber and the smell goes throughout the house, What can be causing this to happen, can it be fixed or do I have to purcahse a new vacuum. This has been going on for about three months now. When you begin to use it, there is no smell but after about 10 minutes or so it comes back. Thank you Marc
  • 76 Answers
Check the belt. if it feels "streched out", replace it.
Posted on Nov 06, 2009
  • 709 Answers
Hi Pmob20,
Remove the brush and clean all the string or whatever may be trapped at the end edges of the brush.  This is usually the case with Bissel vacs, that string or fiber gets trapped at the ends of the brush assembly.
Posted on Oct 23, 2007
Why do the belts keep breaking
Well the problem happens due to the belt If the belt not installed correctly, the rubber belt will grate against one of the components in the roller brush housing. The friction of the belt against the housing produces a pungent burning odor. To correct this you need a right belt, each vacuum cleaner manufacturer produces specific belts for specific machines. An incompatible belt installed on the vacuum cleaner will cause the belt to break or burn.
Good Luck!!
Thanks for using FixYa!!
Mar 26, 2011 | Bissell 3576 CleanView II Bagless Upright...
Bisell 3750 bagless makes a burning rubber smell after about two minutes
The first place to look is the brush roller for hair or thread binding it. Put the machine on it's side and look at the underneath side towards the front. Th brush roller will be there. Take the cover off to expose the roller and see if there is something wound around it.
Good Luck,
Wayne
Aug 14, 2010 | Bissell 3750 Lift Off Bagless Upright...
How do I replace the belt on the beater bar?
if the belt is begining to smell it is friction from themotor trying to drive the roller Sounds like the rooler is getting caught up or jamming this can be taken out and cleaned
Jul 26, 2010 | Dyson DC14 Bagless Upright Cyclonic Vacuum
Bissell lift off bagless making high pitched noise, fan seems to run for 30 seconds after shutting off, and a burning rubber smell, is it the belt, and how easy are they to change
The burning rubber smell is usually the belt. Be careful not to use it on your carpet as the rubber belt can get hot and liquify and really mess up your carpet (if you have one). Here's a link to some instructions for replacing the belt.
http://www.ehow.com/how_4550054_replace-drive-belt-bissell-powerforce.html
Mar 15, 2010 | Vacuums
Bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Mar 08, 2009 | Bissell 6595 Lift Off Bagless Upright...
Brush bar wont turn, Bissell smells like burning rubber
The belt just goes from the motor shaft to the brush roll. Do the ends of the brush trun freely, or is one of them froze up, if so replace the brush roll. If it is ok, try to turn the brush roll by hand, maybe the belt got pinched and won't move.
Aug 25, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Eureka Maxima Bagless brush not spinning in vacuum position
belt doesnt have to be broken, check the metal arm on the vacuum, see if there is build up of old rubber from previous belts, clean the arm that spins the belt and double check to make sure u have the correct belt
Jan 19, 2008 | Eureka 4700A Maxima Bagless Upright Vacuum
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
272 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
