Question about Ice Cream Makers
Carpigiani 141 bar p
Error code 38
Brush Cleaning did not clear the (L / R) HPR> 45F (7C) AFTER 1 HR fault on my Taylor Model C723 soft serve ice cream freezer.
Certain conditions must be met. The machine needs to be empty. The freezer door must be off the machine. The power switch must be off. Once the machine is off, a 5 minute countdown will show. It will also show 4 temperature readings. All 4 of them must be above 60 degrees F. before the countdown will start. Once the counter reaches zero, the Brush Clean Cycle will be reset along with any temperature vs. time error codes. If at any time, one of the temp readings drop below 60 degrees F. before the end of the 5 minute countdown, the countdown will reset to 5 minutes and the machine will not reset. Generally, the freezing cylinders take longer to come to temperature. Even when you run warm water through it first, there is sometimes enough residual cold to bring the temperature back below 60. A successful Brush clean Cycle will display "Power Switch Off---Unit Cleaned" and the 2 digit green display under the main display will reset to 00. if this happens and you turn the machine back on and you are hit with the same message then you may have an issue with one of your boards.
Aug 02, 2017 | Taylor Ice Cream Makers
TAYLOR ICE CREAM MACHINE DISPLAYS HPCO COMPRESSOR.WHAT DOES IT MEAN AND HOW DO YOU REMOVE THIS CODE
HP co is a high pressure issue on the compressor. It could be a restriction in the orifice or the expansion valve. You need a valve and gage set.
Jul 16, 2017 | Taylor Ice Cream Makers
About taylor ice cream machine coc error
For Taylor ice cream machine maintenance, please see our Support page or our Youtube channel. Providing ice cream equipment manuals and maintenance to you for free!
Ice Cream Machine Support Slices Concession
Mar 21, 2017 | Taylor Ice Cream Makers
Have a Taylor C713 Ice Cream machine. Its a new machine to my store and since it arrived the ice cream has been too soft. What can I do to fix the problem?
You need to adjust the viscosity. On your front display, on the right hand side, there is a large ice cream cone. Press the center of that ice cream cone. It'll ask you to enter a code. Using your up and down arrows, enter the code 5231 pressing the SEL button after each number. After hitting SEL for the last number, it will take you to a menu. Scroll down to Viscosity Settings. Hit SEL and then choose left or right. The top number is the current setting. If your only option is exit then press your up arrow to increase the viscosity by (0.1). Then hit SEL. Same procedure for the other side. If its still too soft, repeat the procedure. If your options are change and exit, you will have to scroll up to change and then hit SEL before you can change the setting.
www.softserveparts.com
Mar 09, 2017 | Taylor Ice Cream Makers
Why my Taylor yogurt machine not freezing the yogurt. Model number 339 -58
if cooling light is coming on ck to see if chill plate is getting cold after a few minutes , also visually verify that agitator blades are moving mix around and over chill plate
(chill plate is inside round tunnel that mix bars go thru )
Jan 21, 2016 | Taylor Ice Cream Makers
Gongly soft ice cream machine won't work. Beeping sound when power is turned on. What is the problem?
manual control soft ice cream machine, View carpigiani ...
gongly.en.alibaba.com > Product Categories > Soft Ice Cream Machine
manual control soft ice cream machine,US $ 0 - 1000 / Unit, Air-Cooling, CB, CE, ... Brand Name: GONGLY; Model Number: BQL-838; CERTIFICATION: CE/CB, ...
Machine glace italienne www.gongly.eu - YouTube
? 6:48
https://www.youtube.com/watch?v=D7c2Hiwi6FQ
Jan 3, 2011 - Uploaded by TvSTORE
Machine glace italienne www.gongly.eu. TvSTORE ... Jin Li Sheng Fry Ice Cream Machine Fried Ice Cream Machine Fry Ice Pan Machine ...
Hot Sale Jin Li Sheng BQ322 BQ332 Soft Ice Cream ...
? 1:14
https://www.youtube.com/watch?v=ChUllkdJMlc
Jan 14, 2016 | Ice Cream Makers
Carpigiani
You can call Carpigiani
Mar 14, 2014 | Ice Cream Makers
HPCO is an acronym for High Pressure Cut Out. The most common causes of this code are either an issue with the fan in air-cooled equipment, or an issue with water flow in water-cooled equipment. MOST of the time, someone has mistakenly shut off water to the unit, or moved the machine and pinched a water line with the caster wheel. A restriction at the expansion valve is a possibility but unlikely unless the refrigeration system has been opened recently, possibly to replace a compressor or other component.
If you would like to discuss your issue further with a technician, call 1-800-879-7839. http://www.softseveparts.com/
Sep 12, 2013 | Ice Cream Makers
Ice Cream Makers Logo
125 people viewed this question
Top Ice Cream Makers Experts
ray gallant
Ruth summersides
Are you an Ice Cream Maker Expert? Answer questions, earn points and help others
