Question about Craftsman Garden
Craftsman model 917.258873 transmission
Transmission won't work
Will a toro rear end work on a craftsman 42 in?
I'am not sure,but a Craftsman tractor has a Peerless Transaxle,model # LTH2000. You didn't say,if the tractor you have is a manual transmission or a transaxle type.I will say this,that at Craftsman,they usually have their own brand of transmissions. Another brand might not be adaptable. I know this answer,may not be what your looking for.There is so many,ways a transmission can be installed on the different,brand of tractors. I would call Sears,and ask them,if a Toro would adapt,to a Craftsman tractor,you might get lucky. Sincerely,Brad Locke 11/23/15
Jun 26, 2015 | Craftsman Garden
Craftsman riding lawnmower, model #917 259012 hydrostat stopped working
Check belts. Check transmission fluid level if possible. Check linkage between shifter and transmission. Check belt tensioners under unit above deck.
Jun 15, 2014 | Peg Perego My First Craftsman Tractor...
Transmission
you need to contact a repair shop that works on tractors, they will need to call for parts fluids, you may be better off buying a new one.
Mar 21, 2014 | Craftsman Garden
Transmission won't go into gear
check the lever on the rear to see if it was pulled out to push mode next see if the belt feel off or is loose
Aug 04, 2012 | Craftsman Garden
Craftsman model no. 921.153101 won't go past 20
check the pressure switch also is it before or after a regulator
Mar 22, 2012 | Craftsman Air Tools & Compressors
Will a Craftsman 42" model 486248392 snow thrower
it shooed fit with no problems but first check the crank shaft
to make sure they are the same size that's always ben the
problem trying to switch motors let me no if you need more
assistance
i hope this helps you
bob
Jun 07, 2011 | Craftsman Garden
Garden Logo
24 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
