Question about Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint BF1620 Integrated dishwasher not working
Programme selector not working properly and unable to activate the dishwasher cycle
On off button works, When you switch on, you can select a programme, but when you close dishwasher door , after a couple of seconds there is a bleep but the cycle doesn't start. When you open the dishwasher door again the same programme is lit up, but it is stuck on this until you turn off the power and switch on again.
  • Anonymous Mar 19, 2014
    My kenwood kdw60x10 dishwasher on button does not always work? If you shake the unit it then works? The switch is in the door
  • Anonymous Mar 20, 2014
    Programme cycle buttons not working
  • 460 Answers
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
I have a hotpoint dishwasher BF1620,its leaving a film on everything at the end.
From what you're describing, there might be an issue with the detergent reacting with something in the water. Also, check the water temperature. Any detergent needs to have HOT water--at least 120 degrees or above to activate and clean properly! I also recommend ALWAYS using the high temp wash, boost, or whatever it's called to keep the water very hot throughout the cycle if your washer has that feature.
Sep 11, 2015 | Hotpoint Dishwashers
Dishwasher Hotpoint bf1620
That is not a valid model number
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Aug 08, 2014 | Hotpoint Dishwashers
Hotpoint BF1620 dishwasher will not turn off only at socket. noise is like the continual pump of emptying dishwasher. tries changing programme, turning on off, keeps turning itself on and pumping
There is a malfunction of the washer controller. Hence the mode is not shifting off from the pump as it does not end the programme. Hence you will have to confirm the output of the controller if the drive is short or functioning by itself. Since even after changing the prog there is no change the controller must be replaced. Be sure to clean the pump to see if the drain is working fine. Try this out and hope you get the fault.Good day
Aug 10, 2010 | Hotpoint Dishwashers
Hotpoint Dishwasher BF1620 blew the main fuse circuit in fuse box during mid cycle wash? Re-set main power fuse circuit but now as soon as Dishwasher switched on immediately blows main kitchen power fuse...
This is happening because you have a very bad fault, a Phase to Earth short, problem. Leave machine UNPLUGGED, Breaker/Fuses OUT. do NOT use it, nor Touch it, It is possible to get severe electric shock. PLEASE get a registered serviceman to inspect this unit.
Feb 07, 2010 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Door on Hotpoint Diswasher BF1620 won't shut
To better assist you I need the Hotpoint Model n serial # look like this;
HDA3540NSA Hotpoint® Built-In Dishwasher HDA3500NWW Hotpoint® Built-In Dishwasher HDA3500NCC Hotpoint® Built-In Dishwasher HDA3500NBB Hotpoint® Built-In Dishwasher HLD4040NSA Hotpoint® Built-In Dishwasher HLD4000NWW Hotpoint® Built-In Dishwasher HLD4000NBB Hotpoint® Built-In Dishwasher HDA1100NWH Hotpoint® Built-In Dishwasher
Let me know wish one is yours.
Thank you
May 13, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint bf1620 dishwasher flashing light fault
Hi ,When this happens I keep the button with the letter "P" Pressed until the fault lifgt resets,my row of buttons is inside the top edge of the unit.
Sep 01, 2008 | Hotpoint 23 in. BF50 Built-in Dishwasher
POWER ON-PROGRAM WONT WORK
1. No power to the dishwasherMake sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Aug 10, 2008 | Hotpoint 18 in. BCI45 Slim-Line Built-in...
Hotpoint dishwasher bf1620 - 1st light indicator (heavy soil)flashing. information from hotpoint and manual useless
Hello!
I found out from hotpoint that the first flashing indicator means that the 'float switch' has been activated meaning that the base tray 'may' be leaking. I don't know whether this is a tactic to get their repair man out to fix it.
I was wondering whether there is a way to reset the switch and try re-running a programme as my base tray doesn't seem to be leaking.
I hope this helps a bit
May 02, 2008 | Dishwashers
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
Hotpoint 23 in. BFI62 Built-in Dishwasher Logo
1,307 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
