Question about Hotpoint Aquarius WF000 Front Load Washer
Water wont drain from bush a126 q washing machine
  • 330 Answers
SOURCE: Washing machine wont circulate the clothes, the thing inside wont move
Check the belt, either loss or broke
Posted on Jul 03, 2008
SOURCE: Washing Machine
it sounds like your drain is kluged up, you have to open the bottom cover (make sure you have a bucket) and drain all the water out, remove what ever it is that's in that filter and check the hoses too.
Don't bother calling GE, with what they going to charge you, you could buy your self a new machine.
Best regards
Posted on Oct 23, 2008
  • 399 Answers
SOURCE: My washing machine wont rinse and spin, after
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Aug 13, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint wf860 door wont open
Lay drain hose down, and drain it into a bowl or bucket, if door still does not open, then you have another prob.
Please rate my solution.
Thanks.
Posted on Sep 13, 2009
beltronic205
  • 1466 Answers
SOURCE: the washing machine wont drain out , but will
Could be , you could remove pump and put two wires onto to check but be carefull Electricity kills..Could also be feed to pump from machine,Check 1st nothing is sticking blades , which is most likley
Posted on Oct 03, 2009
Error message E03 coming up on my Bush A146CDB Washing Machine. Any help much appreciated.
fault code 3 usually means:
Not drained in time allowed - washing machine fails to drain water
Check that filter is not blocked or obstructed
Check drain hose is clear of any blockage or obstruction
Those above are checkable by yourself and the ones below need to be checked by a professional.
Check wiring to drain pump
Check drain pump is not defective
Check level sensor or switch
Check wiring to level sensor
All the best
Aug 17, 2016 | Washing Machines
My bush washing machine fills with water drains water want wash.
timer controls it so it is either that or drum drive system-u didn't say if it is or isn't agitating or spinning
Dec 09, 2014 | Washing Machines
I have a Bush WV 1460TVE washing machines and I have a code showing ERR 5 and stops mid cycle. What does this mean?
This is from the manual...
Err5.... CAUSES/SOLUTIONS: Water level not met in 8 minutes/Make sure that tap is turned on and water pressure is normal.(a)
C/S:Height of the drain hose is below 80 cm/Install drain hose within80-100cm of height. (b)
C/S: The drain hose is in water/make sure the drain hose is not in water. (c)
Nov 04, 2012 | Washing Machines
I have a whirlpool awm 8121 6th sense front loader. when i select the cycle, usually rapid, and press the start button the machine commences to fill with water. when it comes time for the actual washing...
If your machine is reasonably old, perhaps take a look at the bushes of the motor . Before that, take the manual and run the test cycles by following the instructions; it might provide you with answers
Oct 14, 2017 | Whirlpool AWM8123 Front Load Washer
It wont drain the water away after a wash we
sounds like your pump may be gone, or could be pipe blocked. to check pipe fill machine take outlet pipe at rear of machine and lay this into a bowl. If water flows ok then all pipes are clear. As water is coming through just put machine onto spin cycle and raise hose to see if water will then pump out.
Feb 17, 2010 | Zanussi FS1255S Front Load Washer
Washing machine wont hold water on any setting
raise the main drain hose to the top of the back control head. there may be a problem with the main hose being to low and the water is gravity siphoning out of the washer.make sure the washer is off when you lift the hose up but do not remove it from the wall,you should here water drain out once it has stopped draining restart you machine and it should fill to the proper level and quit then go into your wash cycle
Jan 31, 2010 | Whirlpool Inglis IP4400 Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Kenmore top loader, water won't drain
sounds like the pump is out. If you are certified to work with electrical, you can check power to the pump .May also be in the timer assembly too which can also be checked for operation.
Jun 13, 2017 | Kenmore Washing Machines
Bosch wfd2473 washing machine wont drain or spin
I have a bosch wfd 2473 washing machine...wont drain,I have had this problem before and resolved it by removing drain/filter plug...normally a button or hair clip....but this time there are no objects blocking.I am guessing the drain pump is faulty and needs replacing...?????
Apr 05, 2009 | Bosch WFL 2063 Front Load Washer
It will not agitate or spin.
needs new bushes to electric motor common fault when the bushes wear down it cuts power to machine this will stop washer from washing and spinning
Jan 11, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hotpoint Aquarius WF000 Front Load Washer Logo
21 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
