Remote not working for mxt digital set top box
I have a mxt digital high def set top box mstb101hd, at first it worked and now i can't control anything with it, i have change batteries several times.
SOURCE: remote control for digital converter box
What brand is your digital converter box? Samsung
It does appear that universal remotes made before these boxes existed accept pre-existing codes.
Here is the Radioshack FAQ for Digital TV converters that they sell:
http://dostuff.radioshack.com/files/DTVConverterFAQs.pdf
Posted on Sep 14, 2008
Techjoel
  • 79 Answers
SOURCE: 4 digit code for handheld remote control to program a Crest Universal remote control
Here are the codes for the RCP3 and RCP5:
RCP3 1023 1024 1074
RCP5 1014 1024 1074
Posted on May 12, 2009
SOURCE: remote control code for the MXT LCD TV
MXT 15.4 LCD 1561D 12V 60W No operation instructions can you help me please
Posted on Aug 08, 2009
SOURCE: Remote control codes for Olin set top box
Try code 1133 . It works on the model HVBT2000
Posted on Jan 09, 2011
SOURCE: I need a remote control
i need the codes for tv
Posted on Feb 26, 2011
I need a code for mxt ked 2061 for all for all remote please urgentley
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Aug 10, 2016 | Televison & Video
What is code for Seiki TV?
that is because sony remote is not a universal and will only control the original sony which it was sold with
Feb 09, 2016 | Sony Televison & Video
Is my apex tv AT2702 high def??
According to apex its not and does not have a digital tuner the only way this can be high def would be 720P meaning 720 lines progressive scan.
Your aspec Ratio is 4:3 this indeed is a standard TV without a digital tuner so you will need a digital setop box or a digital tuner.
High DEF is not considered digital its conidered how many lines are displayed on the TV. For example 720p, 1080p .
  • Silver, 27-inch monaural television; 29.6 x 23.2 x 18.7 inches (W x H x D)
  • Front-panel audio/video input accommodates a camcorder, VCR, or gaming console
  • 3 rear AV inputs (including 1 S-video input), 1 RF antenna input
  • Channel scan, channel recall, closed-caption display
  • Offers V-Chip parental control, sleep timer, auto-off, and a full-function remote control
Technical Details
  • Brand Name: Apex
  • Model: AT2702
  • Display Technology: CRT
  • Display Size: 27 inches
  • Image Aspect Ratio: 4:3
  • Speakers Included: 2 speakers
  • Height: 18.7 inches
  • Width: 29.5 inches
  • Depth: 23.2 inches
  • Weight: 88.2 pounds
Jan 27, 2011 | Apex Digital AT2702 27" TV
Sylvania 15 inch digital/analog LCD TV HDTV. Once
try doing the auto search method on the cable remote. sometimes this works when the codes do not. if it doesn't then it is what it is.
Jun 26, 2010 | Televison & Video
How do I hookup LHT854 Theater System to tv if using comcast digital box? DVD player works fine with sound but but no sound if trying to watch tv.
most cable companies will provide you a high def. cable box for no additional cost. swap digital for high def box. run dvd into high def cable box and run hdmi output from cable box to lg input. hope this helps
Feb 01, 2010 | LG LHT854 Theater System
Remote control code for the MXT LCD TV
Jul 21, 2009 | Televison & Video
Powersurge made my HD setting revert to low def.
Your TV plays High Def material through either Input 4 (uses component cables R,G,B) or through Input 5 (Uses DVI cable).
Today most equipment uses HDMI cable for High Def or it may have a component (RGB) output that you can use. The DVI hookup is best, so you need a HDMI to DVI cable or Component Cables (Red, Green, Blue). You need some source that OUTPUTS High def (ex. 1080i) either through HDMI or component cable. You need to either connect the component cable(R,G,B) from the source to the Input 4 on the TV or connect the HDMI to DVI cable from the source to the Input 5.
You need to set the AV source on the TV to AV5 (if you are using the DVI input) or AV4 (if you are using component cables).
If you want to play Highdef source like Blue Ray then you can just connect the output of the blu ray player to your Tv using either the HDMI to DVI cable or component cable (Red, Green, Blue) and set the TV input to AV5 (for HDMI/DVI) or AV4 (for component).
But if you are trying to get Free High Def from an antenna then you will need to have a component that can OUTPUT high def. The $40 converter boxes don't do this - they simply convert the Digital signal to Analog (non high def). What you need is a High Def TUNER that OUTPUTS High Def. I was looking for one for this same reason and ordered the centronics ZAT 502 HD. But it cost about $80. Then I saw that Tivo had an upgrade deal where I could upgrade my existing Series 2 Tivo to Tivo HD for $99. It has a High Def Tuner in it. So I cancelled my order with Centronics and got the Tivo. In any case if you want Over the air HD you will need a High Def Tuner that will OUTPUT 1080.
Jul 02, 2009 | Philips 55PW9363 55" Rear Projection...
Magnavox 27mdtr20 17
The Magnavox 27mdtr20/17 is a standard def. television produced in 2003 by the Philips-Magnavox Corporation. This particular model was conceptualized long before DTV was an option, and much further before Digital Television Broadcasts were considered a viable option for our current current communications problems.
You will need a DTV box IF:
A) You use an antenna (roof top or otherwise) to watch television
You will not need a DTV converter box IF:
A) You subscribe to cable services, either analog or digital
B) You subscribe to satalite services
For more information on the reasons behind the DTV transition, as well as getting valuable cupons from the federal government to help subsidize the cost of a DTV box, please visit this site:
https://www.dtv2009.gov/
I hope this helped,
Remy
Dec 23, 2008 | Philips 27MDTR20 27 in. TV/VCR/DVD Combo
Program Comcast remote to operate Samsung 46"LCD
Not sure which remote you're using. We have comcast Motorolla box and Samsung LN-T4671F. the code I used was 10812 and it works perfectly.
Go here for more and check the comcast section:
http://www.remotecodelist.com/remotes/
May 18, 2008 | Samsung TV Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
