Question about LG Kp107 Cell Phone
Lg gs117 charger connector jumpering parmanent
My phone is lg gs190 but i do chrge my phone his view msg bad chrging connecting pls give solution of this problem.
Can be a bad or dirty contact, can be a bad charger or a bad cable. Look if all contacts in the connectors are clean and shiny. Try to blow out any debris or dust special in the connector on the phone. Tray a new charger and cable combination.
Jan 15, 2015 | LG Cell Phones
Is it possible to connect headlights directly to battery
yes but its not recommended..in case a short somewhere is visible..do this for testing its much safer...connect a 10 amp battery charger to the backside of the headlight fixture wiring by the wires on the connector(a small jumper wire will help here..) groung goes to any metal surface or battery ground .. then the charger hot lead can be tested with the bare jumper end connected to the headlight wires one at a time.. if a short is present..the charger guage will peg over instantly.. this way, you wont burn up any wires.. good luck.. be carefull..
Jan 21, 2013 | 2000 Buick Century
How do I delete part of the history from my LG GM360
how i can delete my daily calls history parmanently !! not on daily bases ??
Apr 01, 2012 | Cell Phones
Sprint LG Rumor cell phone loose charger wires
Try CPR in NYC. They usually have a 1-3 day turnaround time, and are pretty cost effective. You can easily ship them your unit.
website is www.cpr-nyc.com
Hope it helps!
Mar 30, 2010 | LG RUMOR Cellular Phone
The jumper combination for a slave drive on an LG GSA-4163B
Most CD/DVD drives have a label showing the jumper setting for Master (MA), Slave (SL)and Cable Select (CS).
You only need a single jumper and it is inserted in a vertical position.
There are a group of 6 pins (3 columns of 2 pins) next to the 40 pin IDE connector.
The Slave setting is usually the middle set of pins.
Nov 29, 2009 | LG GSA 4163B DVD±RW Dual Layer Burner
Charging problem
see your charger connector pin broken or not, if broken, that connector must be change to new. But if charger connector still good, maybe fuse for charger protect is blow already. For low cost, make jumper.
Sep 17, 2009 | Nokia 1600 Cellular Phone
My lg rumor wont charger once i place the charger plug in the input at the botttom of the phone ..but once i aplly pressure to the plug it works sometimes how can i fx this problem????
Get a new charger or possibly the charger connector on your phone is worn out. May have to conscider a new phone or warranty replacement.
Sep 02, 2009 | LG RUMOR Cellular Phone
Charging problem of lg rd 3000
lg rd3000 charging jumper
Sep 01, 2009 | Cell Phones
Nokia 1600 charging problem
the fuse is burned go to a cell phone service and have them replaced .
May 26, 2008 | Nokia 1600 Cellular Phone
LG Kp107 Cell Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
