Question about Mtd Garden
Garden Tractor deck problems - Mtd Garden
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 188 Answers
Can you give some detail on these problems please?
Posted on May 08, 2014
SOURCE: Repair Parts Manual / Book Service Garden Tractor
C I am thanking a lot for dealing with my matter and very much I am counting for your help in getting the list of the spare parts with catalogue numbers of my model of the garden small tractor.
I am greeting Ted
Posted on Nov 25, 2008
  • 79 Answers
SOURCE: Craftsman DGS 6500 garden tractor won't engage
Hi
There is a pin in the back by the hitch - make sure it is pushed in. If it is pushed in then check to see if there are any oil leaks under it.
Posted on Apr 10, 2009
SOURCE: removal of the electric(coil) clutch that engages
Problem has b een resolved. I found a pair of channel-loks narrow enough to get down on the back side of the motor. Was able to get a good hold on the coupling that drives the hydraulic pump and loosen the bolt that held the old PTO electric clutch. Once the bolt was removed, it dissassembled very easily. Installation of the new clutch, although it is different from old one, went well also. Be sure to install new unit as one unit,(not in separate pieces).
Thanks for you concern, as I was at a standstill for awhile. Thanks for being there.
Lynn W. Smith
Posted on May 18, 2009
SOURCE: NO FORWARD NO REVERSE
I had the same problem so I looked under the mower and the belt that goes from the engine to the back of the mower was off so I pushed the clutch as far forward as I could and the belt went on it and it worked
Posted on Aug 09, 2009
mickey813
  • 472 Answers
SOURCE: Looking for mower deck belt diagram for a Husky
THAT NUMBER IS NOT COMEING UP CAN YOU SEND ME THE NUMBERS FROME UNDER THE SEAT
Posted on Oct 08, 2009
Craftsman tractor mower deck doesn't go up or down
Make sure lift lever is connected properly and adjusted.
Jun 30, 2014 | Craftsman 26 Hp 54" Deck Yard Tractor
Install Plow on Sears tractor
Going with the garden tractor, I have one. The cutting deck should be removed primarily because the deck could drag on snow. Some of the pivot points for the blade go where the mow deck mounts. There can be an additional fixture to mount on the body of the tractor frame to operate the lift for the blade. There can be additional brackets to support the blade and offer a 4 point mounting system.
Dec 03, 2012 | Garden
Describe your Riding Mowers & Garden Tractors Problem looking for deck belt diagram and size for a 52 inch grasshopper mower series 620
You can go online to the tractor company and look up the owners manuel online. Most decks will have a placard that shows routing. look under tractor on top of deck.
Aug 27, 2011 | Garden
I have a Yard Machine Gold 22 h.p. 8 speed with a 46" deck. Where can I find an online manual that will show me how to remove the deck step by step?
lower deck remove belt from engine disconnect any hangars connecting deck to tractor raise deck lever pull out deck reverse prosess to install
Aug 01, 2010 | Yard Machines MTD Gold 23 HP Garden...
Mower blades stopped while engaged. Couldn't get tractor to start again, even after removing the mower deck. Could this be a mechanical or electrical problem?
There is a safety switch built in,between the mower,and the deck,it is broken,or it is not triggered,cause the deck is not pressing against it.
Jun 09, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
The stars on the lawn tractor deck that hold the
This is a common problem with most of this era tractors the easist way to fix is pick up new ones either at NAPA auto parts store or TSC Tractor supply both carry new star washers to replace the worn ones, and it as simple as removing the old and replacing with the new. Hope this Helps Don
Nov 09, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Hi
Apr 10, 2009 | Craftsman 26 Hp 54" Deck Yard Tractor
Garden Logo
13 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
