Question about Goodman Heating & Cooling
Amana furnace problem red light solid - Goodman Heating & Cooling
5 Suggested Answers
  • 25 Answers
SOURCE: goodman furnace model # GMNT100-4B
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Posted on Mar 24, 2010
  • 53 Answers
from my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
Posted on May 16, 2010
anderza
  • 41 Answers
SOURCE: York Diamond 90 furnace blows cold air
There maybe a few issues. They have multiple safeties on furnaces. With this in mind this process to find the problem would take a Technician to check these safeties. It could be a flame sensor or thermocoupler each senses a flame or heat to keep the gas going. Also the damper for the flue must open for the gas to stay on. There may be more safeties on this and each safety sends a 24 volt current back to control module in order for the gas valve to stay open. If these aren't being met it will try around three times and go into a lock out mode which will keep gas shut off entirely.
Posted on Feb 23, 2012
kingbrizzle
  • 407 Answers
SOURCE: i have a goodman furnace with a solid red light. Says normal operation, but ignitor does not light. Unplugged ignitor and still solid light. Could it be the circuit board or something else? Blower
Usually you can visually inspect the igniter, looking for any cracks or breaks in the element. The best way to check it is with a volt meter to see if your getting the 120v to the plug itself, putting your leads in each of the prongs on the plug. If you are not getting the voltage, it's usually the board. Make sure all connections are tight. The heating sequence will be: 1. Inducer motor starts 2. You will hear a click from the board, it telling the igniter to light. It should start to glow. 3. Next click will be the gas valve opening and flames on. 4. Blower motor starts. Hope this helps!
Posted on Nov 23, 2012
Replaced the gas valve in my goodman furnace now it won't light and red status light stays solid
solid means it is on stand by, no call for heat, put jumper wire between r and w it should start, if it does check t- stat
Oct 27, 2015 | Goodman Heating & Cooling
How do i reset power to thermostat from amana furnace is there a reset for controls?
The manual says it should automatically reset. However to manual reset the unit it says to "interrupt" the power supply. --which I think means unplug/turn off electric to unit for 20 seconds. If you do not have the manual go the manuf website and download it. --Also, this is a Goodman unit. If it does not reset something else it wrong that is preventing the unit from starting for safety reasons.
Sep 01, 2014 | Amana GMH81405DN 140,000 BTU 80% Gas...
Amana 80 sv furnace blowing no heat 4 red flashes
Just a guess unless you read from a paper on the inside what 4 flashes mean but usually it's the igniter
Nov 24, 2013 | Amana GMH950453BX Gas Furnace
Feb 21, 2012 | Heating & Cooling
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Mar 24, 2010 | Goodman GMS90703BXA Heater
I have an Amana Air Comand Gas furnace/AC, it's 4
Hi, If you are talking about an led light at the furnace, and it is blank, it should have a 3 to 5 amp fuse that plugs into the board. Pull it and check to see if the metal element is blown or burnt. If so, replace it. If you are talking about some other red light, please let me know. It sounds as though you have lost the 24 volt control voltage, so see if it has a fuse on the board. Keep me posted.
Shastalaker7
Dec 31, 2009 | Heating & Cooling
Amana furnace
This is no doubt due to failure of the "hot surface ignitor". This device lights the main burners for your furnace, and they fail a lot. I strongly recommend the replacement should be done by a technician.
Ray
Oct 24, 2008 | Amana Heating & Cooling
Amana AC
Hi, the aircondationer compressor was stuck , the thermal control open the red light on , you may call fixya authorized repair service near you you just enter zip code .
Jan 30, 2008 | Amana AP099R Air Conditioner
Heating & Cooling Logo
439 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
