Question about Ovens
Thermador SCD272 upper oven will not preheat. New element and new control board installed.
Upper Oven on a Thermador SCD272 will not preheat. Replaced the element and the 702451 display and relay board (Thermador Recommendation) Still does not preheat.
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
SOURCE: Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Pruneau
Posted on Dec 30, 2007
SOURCE: THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Posted on Dec 08, 2008
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
dmftrucker
  • 1922 Answers
SOURCE: install new element in upper oven lower element
unplug unit from 240volt outlet or if hardwired shut off circuit breaker at house panel, remove 2 screws at where element leads enter oven cavity and pull out element,you may have 2 terminal screws to remove electrical connections from element if it doesn't plug-in, then reverse procedure and its done
Posted on Sep 13, 2009
Dos wo-227 upper oven relay board
I would look on the internet for places that fix boards they usually charge around 120 dolars there is one in texas just type control board repair. Bye
Feb 27, 2016 | Ovens
THERMADOR OVEN SCD302T BOWS CONTROL BOARD
may be a shorted element, but could be almost ANY shorted item. Look at the board for a better idea of exactly which relay is blowing and trace it back. Otherwise a complete disassembly and testing of all components will be needed.
Oct 11, 2012 | Thermador SC302T Electric Double Oven
I am getting an F64 on my thermador electric double wall oven after a few minutes of preheating my upper oven, and the oven turns off. What des this mean?
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Jan 05, 2011 | Thermador SEC302 Electric Double Oven
Dual Oven - upper oven bake element replaced but no heat from it
Usually no internal fuses, and most of the time the controller is rated for fault interupt current.... age will degrade them though...
How did you change the element without pulling out the stove? is it a 'click/plug' in? might be that the socket is messed up...
You should not have to disassemble the cabinet, should just be a few screws and the unit slides out... sometimes hidden behind small movable pannels..
Peace
Feb 27, 2010 | Ovens
The upper oven works fine. The lower oven won't
Make sure you hit the reset switch first... on top of the lower over... behind the panel...they trip easy and "kill" the oven.
Nov 27, 2009 | Thermador SC302T Electric Double Oven
Thermador oven sc302 no heat
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
2.
3.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Mar 05, 2009 | Thermador C302U Electric Double Oven
Jan 30, 2009 | Thermador Ovens
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Replaced the displace board and oven is now not working
I just had a repair company replace the display, control board and wiring harness on SCD272 double oven to correct a dim display (kit part # 492071). Instructions on kit say that all three pieces must be used together for proper operation.
Mar 08, 2008 | Thermador SC272T Electric Double Oven
Ovens Logo
44 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
