Question about Mtd Garden
Cutter deck won't stay on - Mtd Garden
  • Mtd Master
  • 2,760 Answers
Well since you don't mention a model number i'll ask ,a switch to engauge or a lever to engauge deck ? if a switch it could be a safety switch (somethings not set correct to be safe to engauge deck) or a lever to engauge ck the drive belt i'll bet it's worn loose or broke
Posted on May 24, 2014
2 Suggested Answers
The GR8 1
  • 7 Answers
SOURCE: Craftsman 42 inch deck mower.
That model number des not show up as a good number on the http://www.searspartsdirect.com site. Are you sure you have the belts on correctly? If it has 2 belts on the deck & 1 is not installed correctly they work against each other. Safely make sure that each blade will turn by hand. did you take the blades off? If they are too long by just a fraction, they will hit ach other, but that usually makes quiet a noise. Get your book out & systematically go over everything you touched or changed. It sounds like something really simple you have overlooked. you can go to http://www.searspartsdirect.com & enter a good model number & view all of the parts diagrams. Sometimes they are a big help, & at other times they just confuse you more:). Let me know what you find!!
Posted on Aug 13, 2010
JD L110 cutting out when reverse peddle is depressed. Cutter deck is not engaged
Sounds like the safety switch, at the cutter deck lever, failed
Dec 23, 2017 | Garden
Cutter deck height
Not sure what your question means. Cutter deck height is the setting you put your deck on that determines how short you cut your grass. Start out on a medium setting and see if you like the results. Sometimes the grass comes out uneven. If this happens, check your tire pressure on all tires.
Hope this helps! :)
May 03, 2015 | Garden
Replace cutter belt for a Victa Pro 12 ride on
Contact dealership/service center or buy a service manual online
Jan 25, 2014 | Garden
Ride on mower can ride around but whe engage fanbelt for cutter motor stall no power but very thing does turn easy with hand
Sounds like your mower deck safety switch is bad..it is located near the end of the handle that engages the mower deck..try unhooking it and bypassing it with a wire or heavy paper clip...then try mowing if it mows that is your problem..the mower deck will,operate that way but is a safety switch..you need to get it replace,,easy to do yourself..good luck.
Jan 09, 2014 | Briggs & Stratton Garden
Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Aug 10, 2013 | Garden
The play, rewind switches won't stay down
I have advised people before that replacing belts is not the only answer and sometimes people that are not experienced can upset some part of the deck without knowing it. We don't yet know the model or brand of the unit and from the description this kind of points to a Piano key or lever key type deck. I could also be a cam system deck. This complaint of buttons not staying down would not apply to a tack switch or solenoid type transport.
Like Jerry says a visit to a good Tech is the answer. I have been doing tape decks for 40 years and have worked at Sony and Teac service shops. If you need my help let me know. I am near Chicago.
Jul 20, 2012 | Audio Players & Recorders
Craftsman 42 inch deck mower. Model 917.277611 (2007). LT1000. 16.5hp Briggs & Stratton. Springs on cutter deck assembly broke. Had to re-assemble cutter deck. Re-attached springs and tension arms....
Aug 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 | Garden
Stalls when engaging cutter blades
The shaft that holds the blade could be rapped with something or needs a new bearing. Check again next to the deck, try a little WD 40 on the bearing.
Jul 09, 2009 | Garden
I need instructions for the assembly of the cutter deck components etc for this machine.
Hello:
A Breakdown should Assist you in Assembling the Deck Components.
The Following Site Addy has a Breakdown of this Unit. Simply use the Site as if you are Looking for a Part for the Mower and then go to the Breakdown for the Deck.
http://www.partstree.com/parts/
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Garden
Garden Logo
27 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
