Question about Dryers
Bosch dryer SP600/51
Squealling noise
3 Suggested Answers
  • 143 Answers
SOURCE: My dryer is making a really loud noise when the
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Posted on Oct 11, 2009
hunter19_46m
  • 7482 Answers
SOURCE: how do you replace drive belt on maytag gas dryer
Hi david lebron
This solution is for an electric dryer, but the gas dryer would be the same.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be the belt may have slipped off of the motor pulley, or idler arm pulley and/or you have noisy drum rollers.
Note: This method works for most front loading machines.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.
Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.
Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.
Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.
Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.
Move the door and front of machine forward to remove.
This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.
Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:
http://www.expertappliance.com/dryerbeltconfiguration.html
While you have the drum out, I would recommend that you remove and lubricate the drum rollers.
And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise.
You will need to replace the drum rollers if they have flat spots on them.
Please take time to rate me
Bud
Posted on Oct 03, 2012
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Kenmore Elite HE5 front load dryer is making a loud squealling noice...Help?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 06, 2010 | Kenmore HE5 Electric Dryer
I have a LG dlg5988w drying that just started making a banging sound. Are there rollers that need replaced?
yes the belt has a tensioner with a bearing and a roller surrounding the bearing
the bearing can be locked up which will put flat spots in the roller m,aking the banging noise
Sound horrifying at times doesn't it?
Mar 07, 2010 | LG DLG5988 Gas Dryer
417.83142201 just replaced felt pads, upper and
try to lube the rollers on the back wall, where the drum mounts , sometimes the wheel bearings tend to make noise specially when dryer is overloaded and hot
Feb 05, 2010 | Kenmore 83142 Electric Dryer
Squealling noise when starting
Either a belt has broke or one of your support rollers is worn down!
Hope this helped!
Jan 18, 2010 | Dryers
Dewalt dc759 drill squealling noise coming from
yes,the most coomon defect for poer tools are carbon brushes.But,git attention also to the gears,bushings, and bearings if there are loosen parts.Also you get rid to a debris or any small dirt particles that maybe sunctioned by the fan and has been entered in the body of the drill thats why you can hear an squealling noise..Just open and clean it.
Dec 05, 2009 | Dewalt DC759CA Factory Reconditioned 18V...
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
Thanks
Oct 11, 2009 | GE DBSR453EBWW Electric Dryer
Squealling noise while curving left
This is a symptom of a bad CV joint.
Jul 30, 2009 | 1996 Toyota Tercel
When dyer runs it makes a squealling noise like abad bearing>
Could be felt pads and nylon glides on the front drum support are deteriorated.
Could be a sticky build up on the rear drum rollers.
Could be a worn belt tension roller.
Unplug the dryer.
Remove the front panel.
Remove the front drum support.
Remove the belt and drum
Inspect the items listed above.
Replace as needed.
Mar 11, 2009 | Maytag Dryers
There is a squealling noise
THE SUPPORT AND SPIN BEARING IS BAD . WHEN THIS GOES BAD IT DESTROYS THE LOWER SEAL. MAJOR REPAIR . CHECK WARRANTY IT MAY BE COVERED. OTHER WISE REPLACE MACHINE.
FXIT
Dec 06, 2007 | Admiral AW22 Top Load Washer
Dryers Logo
35 people viewed this question
Top Dryers Experts
