HP Pavilion 752N shutting down issue
I have a HP Pavilion 752N that keeps shutting down during installation of windows xp. Has a new power supply. System shuts down, but hard drive and power supply are still running. CPU fan turns off. Could this be a cpu/motherboard heating problem? Or maybe the PS ... even though it's new? Thanks!
  • 2 more comments
  • p1234 Feb 08, 2008
    I have HP Pavilion 752n. Lately, I noticed that the computer shuts down suddenly. I noticed that the processor fan had lot of dust. I cleaned the dust and installed it. The fan still stops suddenly and then computer shuts down.
    Thermal grease is also present between processor and fan heat sink.
    Did anyone have this issue? Please suggest solution.
    Appreciate your help
  • Anonymous Nov 19, 2008
    same problem, computer shuts down, cpu fan stops, HDD and power supply still spin.
  • Anonymous Dec 01, 2008
    same problem and no solution
  • Anonymous Mar 18, 2014
    press power button fan momentarily starts system totally shuts down
Having same problem
Posted on Jun 29, 2008
Ive had the same problem with an hp 533w pavilion... ive even replaced the power supply with a higher wattage (from 200w to 300w) and replaced the hard drive thinking it was a problem with windows or a virus. now im trying to install Fedora on the new hard drive and it shuts down in the middle of installation with the ps and hd still running... any suggestions?
Posted on Mar 12, 2008
    Scholar:
  • 113 Answers
Make sure graphics cards and RAM are secure, now unplug the power and switch the power button on, your led's will flash and die. now find the battery (flat) taking this out will resert the BIOS! check the power lead (red)(black)(black)(yellow) to the HDD(s) and switch it with the CD or optical devices. same voltage etc... as a 'short; in a power line will cause the failsafes to 'hardhill' the computer (shutdown). now: replace the battery and check all power, SATA OR IDE/0 cables are in securely the cooling fans spin effortlessly! and that the fans are plugged in securely. also check for and loose debry, washers etc on the motherboard. now plug the power back in and listen for a faint hum and high pitched (very soft tho) sound from the power supply, this is the sound of capacitors filling/charging. now power up the computer with the XP disk inside and hit the "del" button in the POST (if there is a startup logo hit "tab" first) this will take you to the boot menu. select boot from cd (xp) and hit enter. delete the existing partitions, format in NTFS and let it do its thing! if problems still occur try setting the BIOS TO "failsafe defaults" in the POST too. good luck as always!
Posted on Oct 10, 2007
More information is required for an acurate answer such as at what point during install the computer crashes. This could be a problem with the power supply. the 3 volt rail can fail and still allow the 12 volt rail which runs the hdd to continue running. Try unplugging any periferals that are unneeded for install(internal cards and external devices) as hardware\software conflicts between devices and their chipsets can cause anomolous problems during install.
  • 27 Answers
What kind of power supply is it? its it from hp or a 3 party? how many watts does it have just send me your computer specs to [email protected] so i can check it out
SOURCE:
Hp laptop pavilion shuts off by itself
its either a bad power chord or the power supply or fan
Jan 05, 2013 | HP Computers & Internet
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
My hp pavilion slimline went to the blue screen today that said an error occurred and I should shut down and restart and run the harddrive diagnotics. But when I shut it down, it will turn on, but not...
You can try to do a Power drain of the system ie disconnect all the cables from the pc and press and hold the power button of the tower for 30 to 40 sec. than reconnect only the keyboard the mouse and the monitor and turn it on. try to enter the BIOS page ( keep on tabbing the F10 key to enter BIOS is Windows Vista during the start up and F1 in Windows XP) and from their you can run a Smart test on the Hard drive. You can also try to boot the Pc to the safe mode and check whether the windows loads or not. From the Advanced boot option try to do a Start up repair.
Jul 06, 2010 | HP Pavilion Slimline s3620f Desktop
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
Hp pavilion a1220n shuts dwn after loading hp8500 pr drv xpsp3 os
If you can boot into safe mode, then once in safe mode open system restore and then restore to a couple days prior to the install of the hp drivers. This should fix the problem. If you need to know how to get into system restore let me know your operating system (Vista or XP)
Jun 27, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
System power won't shut down when Windows shuts down.
if same system asking about hp a1320n
drivers and bios updates
try upadating all to see if corrects
May 15, 2009 | HP Pavilion Media Center a1320n PC...
I have an HP Pavilion 752n Win XP SP3 with ASUSTeK Computer INC. P4G-LA REV 1.xx motherboard. I am currently running 1.2 GB of memory. I would like to replace the 256MB memory card with another 1GB memory...
The motherboard can support 1GB of memory, Window XP can manage up to 2GB fairly good maybe more with other setting applied. I would recommend using two 512 memory chips to fill the slots to prevent any memory conflict issues.
Apr 08, 2009 | HP Computers & Internet
Windows xp keeps failing
check the bios and see what the boot order is for the boot devices. Hard disk 0 should be listed after the cdrom drive. this problem you are having might occur if the hard drive is down the list in the boot order, and not checked as being a valid boot device.
Sep 26, 2008 | HP Pavilion dv6000z Notebook
Open Questions:
Computers & Internet Logo
979 people viewed this question
Ekse
Alun Cox
