Question about Asko W6761 Front Load Washer
Asko w6761 front loader
I dropped a marble down the soap dispenser. what panels should i take off to get at it?
  • Anonymous Mar 30, 2014
    nothing works no buttons are doing anything
    nothing you press on the washer is doing anything key symbol locked
    Sergeant:
  • 351 Answers
You can remove the grey drum paddle to get access to the inner drum stick a small screwdriver in the middle hole of the paddle and pull towards you other wise you would be better getting an ako tech to do it because ther are three panels to remove plus a clamp band.if you havent done one before it can be difficult,also check the pin trap it may have gone in ther(filter bottom left corner)
Posted on Mar 02, 2008
Why does water overflow from the sopa dispenser of my asko asea 12002
Is it foamy, if it is then your using top loader detergent.
Aug 10, 2014 | Washing Machines
Asko w6444 front loader drum vibrating quite loudly. Feet are level. Any suggestions.
Check the 3 transit bolts on the backside of the machine. Should be removed. Could also be a problem with the balancing spring on the top of the drum, so the drum tilts a bit forward, and cause noise
Aug 11, 2013 | Asko W6761 Front Load Washer
Water leaking out of soap dispenser?
Disconnect first the mains, power plug off the wall. You could have a clog in your soap drawer; pull the dispenser drawer completely out. There is a tab that needs to be depressed to release the drawer to remove. Clean the soap drawer with an old tooth brush. The usual block could be old soap, softener, etc. (you could also be using too much soap powder). I usually use just above 125ml (my measure cup says ml, I use front loader powder for the 5.5kg load) The wash is very gud. This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Next could be one of hoses has become loose, should be re-fixed. Examine by removing top of the front loader; this will give you a gud view of the pipes.If helped, click.
Mar 17, 2013 | Washing Machines
What size fuse does asko washing machine take
no size given, but here is the part.
http://www.repairclinic.com/PartDetail/Line-Fuse-and-Holder/8801354/1460992?modelNumber=W6761%2FStainlessSteel
Dec 06, 2012 | Asko Washing Machines
The detergent draw won't pull in and out easy. You've really got to 'pull' to get it open and 'push' really hard to make it close.
theres is probably soap inside the track where the drawer slides, just clean it out and you should be fine.
Jul 09, 2011 | Asko W6761 Front Load Washer
The soap dispenser on my ASKO Model 1805 Dishwasher broke, we got a replacement part from ASKO but can't figure out how to get the old one off to replace it?
Remove the outer door panel, the screws around the edge hold it on. The soap cup will depending on serial break be held down with metal flanges or small screws. Bend the flange or remove the screws and push the soap dispenser out.
Appliance & Refrigerator Repair
Mar 23, 2011 | Dishwashers
Asko W6761 Front Loader
check the fuse on the back panel if thats ok check to see where theres power it may be a display board fault.
Aug 27, 2008 | Asko W6761 Front Load Washer
Fault Indication - "Over Flow"
Does manual say to clear drain by running high temp water to clear drain; i dont think so. Now you have to unscrew the back to see where the leak comes from - by pouring plain water into the machine (where u put clothes). Unplug all electrical connections, ie disconnect the machine from the wall socket. Pl post back
Apr 18, 2007 | Asko W6761 Front Load Washer
Asko W6761 Front Load Washer Logo
233 people viewed this question
Top Asko Washing Machines Experts
Marvin
Marvin
Sal De
shaun taylor
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
