Question about Kitchen Ranges
Uneven oven temperature
Ge profile dual fuel stove uneven oven heat when baking. I checked the doors seal with piece of paper it was ok.I checked the oven temperature on the left and right side with a digital thermometer it was ok. The left side gets hotter then the right when baking. I have to rotate the cake so it cooks more evenly.
    Scholar:
  • 43 Answers
It is possible that the thermostat on your oven needs calibration. However, major errors in temperature may be the result of a bad heating element or a door that doesn't close or seal properly, etc. Confirm that the oven is in otherwise good operating condition before attempting calibration.
Most thermostats have a calibration screw located under the knob. Try pulling the knob off and look at the shaft. Some shafts have a small screw located in the center. Rotating this screw will change the trip point at which the thermostat will turn on and off. This is determined by the sensor located inside the oven itself. Some other schemes allow for the entire control to rotate with respect to the scale. You will need to identify the type used on your oven.
Let me know if this helps.
John
Posted on May 09, 2009
Kenmore oven take a long time to heat up, but bakes just fine once it reaches temperature. Is there anything I can do to speed up the heating process?
Start earlier?
>> check all elements for current,
check seals
check temperature calibration (allowed to be 15% ie 180 can be 153 or 207 Celsius!) no wonder Margs' scones cook faster at her house :-)
Oct 15, 2013 | Kenmore Elite Stainless Steel 40" Dual...
GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Aug 31, 2009 | GE JGRP17 Gas Single Oven
Smoke is comming out of the stove when the oven is on
the oven exhaust vents through to the stove. otherwise, the heat will build up pressure and blow the door off. ok, that was drastic. but if there is smoke to the stove, there is smoke in your oven. check to see in anything is burning.
Aug 27, 2009 | GE Profile JTP18 Electric Single Oven
My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Jan 15, 2009 | GE Profile JGSP44 Dual Fuel (Electric and...
GE gas stove
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)as far as the heat from under the clock assy thats the normal vent( nedds to release heat somewhere, not a problem
Oct 06, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Temperature control
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Preheating
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jan 13, 2008 | GE Profile J2S968 Dual Fuel (Electric and...
Oven bakes unevenly and burns food
When foods are burned, soggy, or baked unevenly, it generally means heat isn't being distributed evenly throughout the oven, its escaping out the door or the controls are out of adjustment. 1) Remove any aluminum foil from racks or the bottom of the oven. 2) Check the door gasket and, if necessary, have it replaced. 3) Be sure nothing is obstructing the vent. 4) Reposition the oven racks so baking pans aren't too close to the heat sources. 5) Check your baking pans. If they're dark, they may be burning your food. Reduce temperature by 25 degrees F when baking in dark metal or glass pans. 6) Recalibrate the controls.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Kitchen Ranges Logo
933 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
