Question about True T23 Refrigerator
True t23 not cooling
Recently moved true t23 from one building to another. Worked fine before moving it. Waited about 36 hours before plugging in. Now it runs, but does not get cool. Help...please
  • 87 Answers
SOURCE: Cooler no longer cooling
That POP noise sounds as though it is the overload on the compressor. Although personally I would describe it as a CLICK. If it is then you are either looking at a start device failure (relay or capacitor) or more likely a compressor failure. If you check underneath at the compressor side (black circular unit) and put your hand on the compressor if it is hot you are probably looking at a new compressor. Unless you have electrics for the compressor the only real solution is to have this confirmed by a fridge engineer. If it is the relay I would expect a bill of around £80 if it is the compressor thn it can be between £200-£400 depending on the size of the compressor. Hope this is of some help.
Posted on Sep 11, 2007
farfield
  • 462 Answers
SOURCE: True TD-36-12-S Bottle Cooler
1st check the outter coil and make sure you can shine a flash light through the coil. If not blow out with compressed air and look again. A dirty coil may be your problem.
2nd check the inside coil it may be blocked with frost - ice
3rd the fan both in and out have to be running.
4th check the door seals
you could be low on refrigerant or have a bad thermostat but eliminate all else before going to these 2 problems.
Posted on Apr 26, 2009
  • 274 Answers
SOURCE: True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Posted on Jul 26, 2010
  • 112 Answers
SOURCE: have a true ttp67 that freezes when turned on
Do you mean the product freezes or the coil inside of the box freezes?
If it's the product check the thermostat setting - should be on 3 to 5. Most of my customers use a setting of 5.
If the coil is freezing up it could be the thermostat or a refrigeration problem that would require a tech to check pressures.
Posted on Dec 12, 2010
machinetech7
  • 1344 Answers
SOURCE: I have a True GDM10 that won't cool. Motor runs normal, Evap fan is running, no ice build up, just won't cool. Is this a coolant problem and can a True GDM10 be recharged? See no hook ups in t
First let me ask, are you sure the compressor is running? If you verified that it was running by vibrations in the compressor area just know that the condenser fan can also cause those if your machine has one. The way to tell is if the compressor is generating heat. With that said, assuming that the compressor is running, and all applicable fans are running, you need to determine if the machine was losing cool over time or did it happen overnight? If the latter of the two you'll need to isolate where the leak is, be it the evaporator or the compressor area. To actually add freon to the system if no access ports are available you;ll need to get a piercing valve, I personally use pt# bpv-31 bullet piercing valves.
Posted on Jun 16, 2012
Frig freezer wont get cold enough after move . 35 degress then back up to 45 . cleaned everything good . coils everything . worked fine till moved . waited 24 hours after move to plugg in . help
Hi Kim, Before you check out the link below, Read about your refrigerator not cooling?Is your older or newer model refrigerator plugged in, getting power, the lights are on inside but the fridge will not cool and the freezer won't freeze? If your refrigerator or freezer has suddenly stopped cooling and the freezer won't freeze, we have multiple solutions for you.If you hear a clicking sound coming from the back of your refrigerator/freezer, then the problem is most likely the compressor is overheating or not getting proper power and will not start. The compressor is the component on your refrigerator that allows your refrigerator to cool. If this component is not working properly your refrigerator will stop cooling. Most of the time the compressor is not the component that has failed.
Refrigerator Is Not Cooling What To Check And How To Fix
Apr 03, 2016 | Refrigerators
Why doesn't it run after being moved across town?
laying down is a no no and has to stand turned off for about 24 hours so the oil returns to the compressor . quite likely you have burned the compressor up using it too soon .
Sep 20, 2015 | Refrigerators
Is my defrost timer broken or my thermostat? The freezer was holding -30 temp but now is at +30.
Is the compressor running? If not - the timer could be stuck in defrost mode. If it is ruinning, then the freezer coil should be cold. If it is choked with frost & ice - then the defrost heater isn't getting powered (bad timer or defrost terminator - or is getting powered but has burned out.
You should allow the ice and frost to melt completely before turning back on again. Typically ice and frost don't build up so bad in a few days time to cause the temperature rise you're describing If getting cold - the compressor and refrigerant is likely OK, if not the defrost circuit is suspect. If compressor running but not getting cold - a refrigerant leak / charge level may be causing the problem.
May 18, 2015 | Arctic Air 22 cu. ft. Commercial Freezer...
Power steering will not move
Check if there's enough power steering fluid in resovoir
Jul 21, 2012 | 2003 Pontiac Montana
Against my better judgement, I layed my refridgerator down during transport from one location to another. I waited approx. 12 hours before I plugged it in and it is not cooling properly. Is there...
Here is a tip that I wrote on moving refrigerators...if you did not do it this way then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is the best way
If you already have moved it wrong, you can sometimes get it working by plugging it in and unplugging it a number of times with an hour or so in between.
heatman101
Jan 16, 2011 | Whirlpool GS5SHAXN Side by Side...
Layed refrigerator on its side to move waited 3 days plugged it in worked fine for 3 days then electrical smell and it doesn'tget cold. can i fix it
Fan motors are great item to give off a burning smell when failing.
You have one in the freezer compartment behind the back panel.
You should be able to hear it when you open the door to the freezer.
A second motor is behind the cover panel at the bottom rear of the machine near the compressor. Failure of either motor can cause no cooling, and a burning odor.
There is a calrod heater located in the freezer compartment behind the real panel that can short and burn, but it would not immediately cause rapid cooling failure unless it burned a hole in the evaporator causing a total loss of refrigerant. ( I've seen it happen, but it's rare). Beyond those items wiring runs throughout the machine and can be suspect especially if the machine was transported on it's side. Refrigerators should always be moved in an upright position.
Nov 02, 2009 | Kenmore 50522 / 50524 Side by Side...
DAR482BLS does not chill
If you have just moved it, the compressor reservoir may be flooded. Give it a few hours to settle and that should do it.
May 27, 2017 | Danby DAR482BLS Compact Refrigerator
Refrigerator-lights on not cold
If has a electronil controlboard i would say it is faulty.Cheak on warranty.
May 11, 2009 | GE PSC23NGS Side by Side Refrigerator
True T23 Refrigerator Logo
59 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
