Question about T-Mobile Dash Smartphone
My Mio P350 stuck during the boot process. - T-Mobile Dash Smartphone
Hi,I want driver for Mio P350,I have windows 8.1
Automatically get recommended drivers and updates for your hardware
http://windows.microsoft.com/en-us/windows7/automatically-get-recommended-drivers-and-updates-for-your-hardware
Dec 19, 2014 | Mio P350 Pocket PC
Does anybody have a start up code for mio m419 lm
Go onto the Mio.com website and contact section under support. Send a message with the serial number requesting the key.
Jun 12, 2014 | Mitac MIO P350 PDA POC PC+ GPS SAT NAV...
I need to replace battery. Is it easy to get back off? Manual says I need to take it to repair shop
Basically to take any phone or pda apart, unscrew all screws and look for hidden screws under soft objects or labels etc.
ones all screws are out, use a small flat screwdriver or a case opener tool to carefully open the case of the phone or pda. it should snap open, very likely plastic holders on the corners that keep the case closed, carefully snap them open / off, don't break them.
May 13, 2009 | Mitac MIO P350 PDA POC PC+ GPS SAT NAV...
Boot up stuck
you probably need to reset the unit....look for a pinhole, and find something small that will fit into it, and press, this will reboot the unit....
May 08, 2009 | Mitac Mio P350 GPS Receiver
Screen on my mio p350 is frozen, reset doesn't help
You will have to do a "Factory Reset".
***You Will Lost All Your Data***
While you reset the device by pressing the little button on the bottom with the stylus,
Hold "UP" on the direction pad.
Keep holding for about 30 seconds.
You should then be prompted to do restore it to factory settings.
Let me know if this doesn't work, and we'll go from there,
Simon
Was I Helpful? Let Me Know By Rating Me!
Nov 21, 2008 | Mitac Mio P350 GPS Receiver
My mio p350 was playing up. it then hard reset it self. it came back on line and was working for a few minutes then stalled. i soft reset it and now it will not come back. it stays on the first page...
Mio P350/550 Hard Reset 1. Turn off the pocket pc (on/off button ).
2. Push the joystick button up (to the screen).
3. Turn on the pocket pc.
4. keep holding on the joystick button for 30 second.
Oct 30, 2008 | Computers & Internet
MIO P350 cannot get GPS signal
What navigation software you use? All navigation software need to install correct Port and Baud Rate for work - please check it in you software.
If you need help or professional GPS-consultation or unlock you PNA, update navigation maps - please ask
http://www.goodslowprice.com/en/unlock.htm
Mar 28, 2008 | GPS
Mio P550 how do i do a hard reset
on/off switch in "off" position for at least 30 seconds, then turn it in "on " position, power on and "reset". You'll lose all your data and all the installed programs.
Alternative: using the screen options, go to "system info", and choose "hard reset".
Beware: pushing the joystick down while doing a reset will get you a boot menu with memory-formatting options. Choose "exit".
Otherwise look into xdadevelopers forum (Google it or go to, say,
Mio P550 / P350 ROM upload [Archive] - xda-developers
A good idea would be to backup your data in the first place- just a hint.
Enjoy.
Dec 09, 2007 | Mitac Mio P550 GPS Receiver
T-Mobile Dash Smartphone Logo
121 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Martin Murray
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
