Question about Fisher Price Rainforest Bouncer
Chair to laid back need to be more upright? - Fisher Price Rainforest Bouncer
How do you correct or replace the Apex 2000 Storz exam chair that will not hold in position when tilted back?
This should be visually diagnosed to get an accurate identification of the issue. That said, I would look to the tilt motor having broken teeth on the sprocket or a broken drive gear. Also the drive chain may be loose enough to allow it to slip on the sprocket. In most cases, the issue is with the tilt motor mechanism. Removing it will determine if an adjustment is all that you need or if it needs replacement.
May 12, 2014 | storz SMR Apex 2000 Exam Chair
I have a jazzy 1107 power wheel chair the back wheels are leaned outward i dont think the back wheels should be leaned outward i think this is what is causing me not be able to be able to turn properly....
Have some one check out that the section has not become loose or broken. IF the wheel rubbers are damaged then you will have trouble regardless of what you do. I consider it paramount that the chair is in top condition for your needs. Have the manufacturer's service agent fix it for you.
Sep 22, 2013 | Health & Beauty
How do i recline the Peg perego Prima Papa high chair?
Lift up on the handle in the middle on the seat back. There are usually 4 stops along the way from upright to recline.
Feb 22, 2013 | Peg Perego Prima Pappa High Chair
What is a high back beach chair?
A high back beach chair is the opposite of a recliner chair. On this chair, people sit almost in an upright position.
Aug 19, 2012 | Garden
Hi there, how do i adjust the chair on the fisher price starlight papasan swing? It is laying pretty low and i want to adjust it for the baby to sit more upright
If you haven't already figured this out, there are two pressure things on the underside of the swing. Just sit to the side or back of it to see them, push them both in, and tip it into the position you want. The upright position isn't upright like a chair, it's still a little reclined, so if you need a boost just slip a rolled up blanket in where you need it.
Apr 03, 2011 | Fisher Price Starlight Papasan Cradle...
Hi - I have to move a Daewoo upright fridge/freezer. It is too high to stand upright in my van, can it be laid on its side? Thanks
Yes, it can be laid on its side but when you get it to its location, stand it up and DO NOT plug it in for a few days to let the compressor oil run back down out of the system. After that everything will be fine.
Nov 01, 2010 | Refrigerators
Chair stuck in upright position,will not go down but the back of the chair moves backwards and forwards
Hard to say definitively without know the make and model of your particular chair but if your chair is anything like mine the same lever underneath it that makes the chair go up and down will also fix this: the lever can slide left and right as well as being flipped up and down. That's what always fixes it when it happens to my chair anyway.
Jun 02, 2010 | Mobility (EKEYP0001-R) Keyboard
Sears upright freezer will not come on after a move. Worked fine when we left the old place. Model 253.9244410
Sometimes when you move these, they hydraulic in the line if they were laid on it's side to move. Time is all it needs in this case- about 24 hrs. If it was not laid down, pull the back cover off the freezer and look carefully for loose wires. There will probably be a wire off either there or behind your temperature control.
Apr 23, 2010 | Freezers
Fisher Price Rainforest Bouncer Logo
77 people viewed this question
Top Fisher Price Baby Gear Experts
romney2012
Lyle Siemens
Lyle Siemens
Josh Whitehead
Josh Whitehead
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
