Question about IBM NetVista PC Desktop
My IBM NetVista windows 2000 professional cannot detect Bios.. It said BIOS was not install? Also cannot startup...man i need a new computer
  • 46 Answers
Ur right about that..and Win2k is not safe to get on the net either. It is hack_able.
Posted on May 24, 2009
I cant reformat my ibm pentium 4 where can i find the advance bios i press all the functions but icant see the advance bios
Try the below steps and I hope it'll work for you.
1) Shut down the operating system and turn off your computer.
2) Press and hold down the F1 key, and then turn on the computer.
3) When an IBM or other logo is displayed or if you hear repeating beeps, release the F1 key. The IBM BIOS Setup Utility will start.
4) Select "Start Options" from the first menu.
5) From the Start Options menu, press <Enter> on the top bullet labeled "Startup Sequence" (it is above all the other options). This brings up a new "Startup Sequence" menu.
6) Change boot order as needed using arrow keys.
Jul 24, 2012 | IBM Netvista Intel Pentium 4 2.4GHz /...
Will try to make a long story short...Attempting to install Windows XP Prof. on a friend's IBM NetVista 6645 Model W2U which he purchased from someplace. It already has XP Prof. installed, but my friend...
Can you get into the BIOS configuration to enable the CD and USB drive?
If so enable these devices.
Check the interior of the desktop to see if the CD drive and USB connectors are still connected.
Nov 02, 2009 | IBM NetVista PC Desktop
Unable to Acces BIOS on IBM Netvista 607931u w/ Phoenix ROM BIOS
When the IBM Setup Utility program prompt is displayed, quickly press F1.
The prompt is displayed for only a short time.
if you dont see the prompt, tap F1 repeatedly as the computer starts. If it says "starting windows" you've let it go too far and will have to restart again and repeat the process to get into the bios
REGARDS..
Apr 09, 2009 | IBM NetVista PC Desktop
IBM NetVista 6790 31u - Need to reformat single HD computer.
The PC comes with a restore CD. This to reinstall or repair your OS which is a genuine copy(look for the sticker)Use te restore CD while startup and follow the instructions...........sodeep
Apr 07, 2009 | IBM NetVista PC Desktop
My IBM Netvista 1000MHZ and RAM128 its failing to load windowsxp
You need to check your Bios settings to make sure you haven´t turned on a certain hardware devices that is causing conflicts with I/O settings, try defaulting the Bios settings. you can activate the bios by pressing the F1 or F2 or F10 Or the Delete key when you turn on your computer.
Mar 30, 2009 | IBM NetVista PC Desktop
How to install Windows Vista On IBM NetVista 830331G
newer os like xp and vista have many new power management feautures like acpi-advanced configuration power interface.. when booting your pc press DEL or f2 to enter bios and check if your bios supports this feature.. i have not used ibm pcs but still check with this..
Feb 10, 2009 | IBM Netvista Intel Pentium 4 2.4GHz /...
Which one key to press to togin to bios setup??
If this is an IBM Netvista you start the Bios by pressing the F1 key while the computer is starting up, press it many times as soom as you hear the computer startup beep.
Nov 19, 2008 | IBM NetVista Socket 370 Barebone Kit /...
IBM Netvista desktop bios problem
this is more like a workaround that I used on a laptop which cd room drive just failed (and which I did not want to replaced as it was more expensive than the whole laptop)
If you can't select the device you want to boot from.. you may want to partition your hdd and format it so it loads a dos operating sytem .. use another machine and a win98 startup disk to do this then copy your I386 folder from your winxp cd into the new formatted hdd so when you put the hdd back into the IBM machine it loads dos and then going into the I386 folder you can run a winnt command for you to install the os.
Jul 31, 2008 | IBM NetVista PC Desktop
Bios problem
bios for ibm is at ibm.com and you should never update bios if you dont know much of computers but always use software to flash bios from windows... ibm.com will be good to download bios, the other part is up to you, because if you are clueless on this matter you better take your computer to an it technician before braking it down.
Mar 20, 2008 | IBM NetVista PC Desktop
IBM NetVista boot Prob
You don't have to update your BIOS just to have it changed into English... It's all there, your problem is how to get into that change language area... Check your system manual I am sure you'll find what you need...
Nov 04, 2007 | IBM NetVista PC Desktop
IBM NetVista PC Desktop Logo
100 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
