Question about Refrigerators
Samsung repair manual
HOW DO I REPLACE THE WATER DISPENSER LEVER KIT ON MY SAMSUNG RL43WCIH REFRIGERATOR?
  • 1314 Answers
SOURCE: Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Posted on Feb 17, 2008
SOURCE: water dispenser lever on Frigidaire
My Frigidaire side by side is a little different from tech17's solution. It has no slots for a screwdriver to pry it off. It is a model FLSC23F6D55 manufactured 3/05. There is a semicircular spill tray in the bottom of the recessed water station. Just pry out the tray, from the bottom corner of the frame from the side and or bottom. (I did this with a knife blade.) This tray is a snap-in fit. Then you will see three phillips head screws in the bottom of the frame. Take out these three screws and remove the frame by lifting up on it and pulling out at the bottom. Then take out three more phillips mounting screws to remove the processor card and key pad. You will then see the top of the water lever mounting. The lever comes out by removing two more screws that hold the pivot shaft of the lever. (These last screws are a little more diffiucult to get to, but not anywhere near impossible.) I wish you well.
Posted on Jul 13, 2008
SOURCE: Ice and Water Dispenser not working on KSCS25FKSS01 KIT.AIDE MODEL
This is a known manufacturing defect. The problem is that the wire that some of the wires that run between the door and the rest of the refrigerator have broken and, believe it or not, the only solution is to replace the entire freezer door. Whirlpool is covering the cost under a hidden warranty...call them and describe the problem.
Posted on Jul 20, 2008
  • 9 Answers
SOURCE: I need to replace the Ice dispenser lever in ny
Unless the old one actually broke, you can re-install it if it merely fell off. Use a mirror and a flashlight to see the hole on the side toward you so that you can re-insert the lever that goes towards the front, then re-insert the lever into the back hole. If the lever actually broke, the new lever will come with directions on how to install it.
Posted on May 14, 2009
SOURCE: My Jenn Air refrigerator ice maker quit working
My Jenn-Air refrigerator (JRSD2790) quit making ice, dispensor works, water dispensor works. Do I need to replace the entire
ice maker?
bjones03@comcast.net
Posted on Feb 13, 2010
Constant, slow leak from water dispenser on whirlpool refrigerator
you might need to replace the bottom section and spare parts should be available readily online. I had a slow leak on my samsung side by side and it was resolved once i bought a new part...Hope this is of some use but not an expert.....
Jan 02, 2013 | Whirlpool Refrigerators
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
I have a water/ice dispencer in the door of a side by side Whirpool model no. GS2SHEXNT00. The water dispenser leaks, sometimes a large run of water other times just a drop. I took the front cover off the...
Heat from the night light will deteriorate the plastic tubing of the dispenser. Cracks in the tube will allow water to go out the side of the tube as well as in the glass you're filling. There are repair kits available from online appliance parts companys.
Apr 10, 2017 | Whirlpool 21.8 cu. ft. Side-By-Side...
The water dispenser will sometimes drip and doesn't stop. It doesn't stop by pulling forward on the lever, I have to push it in as though I'm dispensing more water and that usually stops it. If I don't...
There may be several reasons for this like a leaking water control valve, air in water lines or you may just need to replace the dispenser water line with a kit Part Number 8201537 Try unplugging the dispenser power on rear of refrigerator and tell me if that stops the flow. let me know, Sea Breeze
Apr 20, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
I have a Hotpoint HSS25GFTA BB. The water is not dispensing. I know the microswitch is making and water is pumping because I disconnected the tube on the bottom of the frezzer door and it squirts water...
Water is frozen inside the water tube that runs inside your freezer door. If you empty out the food in the door, you can use a hair dryer on medium heat to warm the frozen piece so it loosens enough the dispense out. Every 5 minutes, close the door and check if water dispenses. It takes between 15-30 minutes.
GE makes a dispenser water tube heater that attaches to the top of the dispenser tube to prevent frozen tubes. The part is WR49X10173. Check to make sure it is compatible with your refrigerator. Amazon and Walmart.com sells the part. Good luck!
Mar 16, 2017 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Whirlpool side by side with a broken water dispenser
you may have a sticking water lever or a bad water valve.
the lever can be changed from the front and you should know if it sticks.
the water valve can be replaced from the rear of your unit. it is the plastic part where the water line hooks up to the unit.
Jan 03, 2010 | Whirlpool GS6NBEXR Side by Side...
May 14, 2009 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
Water dispenser lever on door broken off.
Yes, the levers are easily ordered and replaced.
get manual, obtain part number, order part, replace part. use these websites for help http://www.retrevo.com/samples/Frigidaire-manuals.html#Refrigerator
https://www.appliancezone.com/
Oct 15, 2008 | Frigidaire FRS26R4A Side by Side...
Samsung RS21DCNS: Ice maker fills up but water dispenser does not dispense water
the fridge is making a noise , sounds like a fan catching and the water will not flow
the firdge is a Samsung RS21DCNS 19.6CF
Oct 04, 2008 | Refrigerators
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
