Uninstall juchect.exe - Computers & Internet
How do I uninstall "xwryggiya.exe" tracking software that is slowing my laptop?
Run Advanced System Care from iobit.com. That will clean your registry and allow you to remove these add ons. Oh yes and it's free!
Dec 29, 2014 | HP Pavilion dv6000z Notebook
Tip
HP printer UNINSTALL using CD
<p><span><b>Resolution:</b></span><br /> <ol> <li> <span>Run the uninstaller from the SETUP.EXE driver</span> <li> <span>Delete printer from Printers folder</span></li></ol> <p><span><b>Removing printer using the SETUP.EXE driver:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver as copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <p><span><b>Deleteing Printer:</b></span><br /> <ol> <li> <span>Run the uninstaller from either the printer CD-ROM, diskettes, or the downloaded Setup.exe printer driver.</span> <li> <span>Go to Start, then Run and in the Open line type X:\Setup.exe, (where X is the CD-ROM drive or the floppy drive or the Directory on the hard drive where the downloaded driver was copied to.</span> <li> <span>Follow the on screen instructions.</span></li></ol> <br />
on Mar 10, 2011 | Office Equipment & Supplies
Tip
How to uninstall deep freeze
To uninstall the software Deep Freeze must first be disabled and then uninstalled.
To disable Deep Freeze:
1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you
can press Crtl-Alt-Shift-F6. You should now see a password dialog.
2. Enter your password and click OK. If you have not yet entered a password you should be
able to click OK without entering anything. You should now see a dialog with boot options.
3. Select "Boot thawed" and click OK. This will disable Deep Freeze on the next reboot.
4. Reboot your machine. After the machine reboots you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze to this machine. By
default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for
versions 6.X.
2. Run the installation file (DF5Std.exe or DF6Std.exe).
3. Select the option to "Uninstall"
4. The software should uninstall and reboot the machine. When the machine reboots, Deep
Freeze should be uninstalled.
on Mar 15, 2010 | Computers & Internet
I have computor running Win XP pro I am getting Spupdate is not responding when shuting down the computor. how do i fix this
Here is what it is, SPUpdate.exe is part of SPUpdate and developed by SoftThinks - Dell according to the SPUpdate.exe version information.
SPUpdate.exe's description is "SoftThinks Update Tool"
SPUpdate.exe is digitally signed by Dell Inc.
SPUpdate.exe is usually located in the 'c:\program files (x86)\dell datasafe local backup\components\DSUpdate\' folder. if you do not require the software , then i would recommend , uninstalling it , if it is indeed an error from a previous installation that you can no longer uninstall , try reinstalling the software and then uninstalling, after this use a registry cleaner to clean that up too, if you need further help or instructions dont heitate to ask
Dec 17, 2014 | Dell Computers & Internet
Cannot uninstall deep freeze
uninstall it using administrator password
May 10, 2011 | Computers & Internet
How i uninstall deep freeze software
HI Good day!! do the following
Disable Deep Freeze before uninstalling it.
1. Hold down the shift key and double-click the Deep Freeze icon. Alternatively, you can press CTRL+ALT+SHIFT+F6.
3. If you have not yet entered a password you should be able to click OK without entering a password.
4. The Boot Options dialog is displayed. Select "Boot Thawed" and click OK. This will disable Deep Freeze on the next reboot.
5. Reboot your computer. After the computer reboots, you are ready to uninstall Deep Freeze.
To uninstall:
1. Locate the installation file you used to install Deep Freeze on your computer. By default, the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
Deep Freeze is uninstalled and your computer is rebooted.
Oct 12, 2010 | Computers & Internet
Samihullah
  1. Hold down the shift key and double-click on the Deep Freeze icon. Alternatively, you can press Crtl-Alt-Shift-F6. You should now see a password dialog.
  2. Enter your password and click OK. If you have not yet entered a password you should be able to click OK without entering anything. You should now see a dialog with boot options.
To uninstall:
  1. Locate the installation file you used to install Deep Freeze to this machine. By default the name of this file is called "DF5Std.exe" for versions 5.X and "DF6Std.exe" for versions 6.X.
  4. The software should uninstall and reboot the machine. When the machine reboots, Deep Freeze should be uninstalled.
Mar 15, 2010 | Sony VAIO PCV-W600G PC Desktop
How to uninstall deepfreeze frm pc
To uninstall:
Let me know if this will help
Regards
Nov 27, 2009 | Cell Phones
How to uninstall the norton product
please go ahead and download www.symantec.com/nrt ,tool and run this tools and after running this tool please restart the computer and it will remove the norton products completely out of your computer
thanks....
Nov 18, 2009 | Symantec Norton AntiVirus 2002 8.0 for PC
Want to uninstall deep freeze
Give this a go....
To uninstall:
Hope this helps.
Andy
Dec 15, 2008 | Computers & Internet
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
