Question about Kenwood KRF-V5060D Receiver
I want to dismantle a krups xn 3006 - Kenwood KRF-V5060D Receiver
Krups gusto 880 - My steam tap doen't pass the first sign to max.
Unless you are able to dismantle the unit and pull the tap to pieces to free it up you are going to be doomed. That part is part of the element assembly upper housing and it is obsolete according to Krups.
Apr 05, 2015 | Krups Coffee Makers & Espresso Machines
How do i clear the air bubble in the nespresso machine?
OK fill the tank and only use water press the small cap botton and after 5 seconds stop the machein and do the same again untill the pump gets the water into the system
Sep 17, 2014 | Krups Nespresso Essenza XN 2009 Espresso...
Nespresso xn 2003 - water comes through without a capsule but when a capsule is in place the water goes straight into the catch tray?
at the back of the capsule holder there is a metal that correspond
with the sensor sow your problem is the sensor is not finding the capsule holder at the and of the capsule holder do you see the magnit if not replace and try agian
Jul 08, 2014 | Krups Coffee Makers & Espresso Machines
Where can I get spare parts for the Krups Nespresso Citiz XN. specifically the Drip tray and the base it sits on
Why don't you try "Krups" ? I would think this would be the best place to start. Ask them if they stock the spares and if not where they are available.
Feb 24, 2012 | Nespresso Coffee Makers & Espresso...
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
There is no power in my krups xn 2000 nespresso maker . had it open and measured points from end of the cable and the control board looks good anyone know if there is something else i can do many thanks
Frequently the power button / power switch seems to be broken. Apparently a tiny film of grease builds up between the conductive material in the rubber button and the IC board.
See this video on youtube how to open it up and remove the dirt. I repaired my machine this way, takes 15 minutes, and I was surprised how only a thin film of grease could cause the malfunctioning of the button.
Feb 09, 2010 | Krups Coffee Makers & Espresso Machines
Kenwood KRF-V5060D Receiver Logo
66 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
