Question about Krups Small Appliances Espresso Machine
Krups xn 3006 will not load cartridge
The Handle is moving freely and not fully openning the cartridge slot
W do I get a Moen single handle faucet retainer clip to seat fully?
The cartridge needs to be fully seated for the clip to line up with the slots.
Dec 29, 2014 | Moen Plumbing
How to remove the printhead from an HP 6520
Step one: Remove the old cartridges
  1. Press the Power button ( ) to turn on the product, if it is not already turned on.
  2. Open the cartridge access door. The carriage moves to the center of the product. Wait until the carriage is idle and silent before continuing. Figure 1: Open the cartridge access door c02937518.gif
  3. To remove an old cartridge, press the tab on the front of the cartridge, and then pull it up to remove it from its slot. Figure 2: Remove the cartridge from its slot c02938232.gif
  4. Repeat the previous step to remove each of the cartridges.
Step two: Remove the old printhead
  1. Lift the latch handle on the carriage until it stops. Figure 3: Lift the latch handle c01795083.gif
  2. Lift the printhead to remove it from the carriage. Figure 4: Remove the old printhead c01795084.gif
    Regards
    Gary
Jul 07, 2014 | HP Photosmart 6520 e-All-in-One -...
Where can I get spare parts for the Krups Nespresso Citiz XN. specifically the Drip tray and the base it sits on
Why don't you try "Krups" ? I would think this would be the best place to start. Ask them if they stock the spares and if not where they are available.
Feb 24, 2012 | Nespresso Coffee Makers & Espresso...
I don't know how to load the ink into the printer of the iP 1600 Canon pixma
How to install ink cartridges
1. After confirming that the printer is powered on, open the front cover. The ink cartridge holder moves to the replacement position.
2. Take out an new cartridge from its casing and gently remove the orange protective tape in the direction of an arrow.
Caution: Do not attempt to reattach the protective tape once you have removed it. Do not touch the gold electrical contacts or the print head after removing the protective tape.
3. Insert the color cartridge into the right slot and then the black cartridge into the left slot.
Note: Push up on the nearest side of the cartridge until it clicks into place.
4. Confirm that the ink cartridges are installed properly.
(A) The ink cartridge is not installed properly.
(B) The ink cartridge is installed properly.
5. Close the front cover. Wait until the preparatory operation is complete; it takes about one to two minutes.
How to remove ink cartridges
2. Remove the ink cartridges.
Note: Handle the ink cartridges carefully to avoid staining clothes and surrounding work area.
Apr 25, 2011 | Office Equipment & Supplies
My Krups XN2005 coffee machine switches itself off as soon as I try and brew coffee from the pod. Any suggestions?
My Krups Nespresso XN2005 machine turns itself off when I try press the start button- any solutions ?
Feb 21, 2011 | Krups Nespresso Essenza XN 2009 Espresso...
Single handle balances cold & hot. First cold then hot at full counterclockwise rotation. Only a trickle of cold coming through but hot side works fine. Appears to be a ball valve. What could...
there could be dirt in the cartridge or the integral cold side shut off is not fully open. the integral shut off has a slot for a screw driver. the slot is to face the same direction as the pipe coming into it to be open and straight up and down to be off.
Dec 29, 2010 | Moen & Posi-Temp Single Handle Shower Or...
There is no power in my krups xn 2000 nespresso maker . had it open and measured points from end of the cable and the control board looks good anyone know if there is something else i can do many thanks
Frequently the power button / power switch seems to be broken. Apparently a tiny film of grease builds up between the conductive material in the rubber button and the IC board.
See this video on youtube how to open it up and remove the dirt. I repaired my machine this way, takes 15 minutes, and I was surprised how only a thin film of grease could cause the malfunctioning of the button.
Feb 09, 2010 | Krups Coffee Makers & Espresso Machines
How do i install ink cartridge for HP 4355?
To install the ink cartridge
1) Press the On button. After you press the ON button, wait for the print cartridge prompt before continuing.
2) Open the print cartridge door. Lift the print cartridge door. The print cartridge moves to the right side.
3) Remove tape from both cartridges. Pull the tab to remove the tape from both print cartridges.
Important : Do not touch copper-colored contacts or retape the cartridges.
4) Insert the tri-color print cartridge.
Caution : The device must be On before you can insert the print cartridges.
a) Slide the tri-color print cartridges into the left slot.
b) Push the top part of the cartridges firmly up and into the slot until it snaps into place.
5) Insert the black print cartridge.
a) Slide the black print cartridge into the right slot.
b) Push the top part of the cartridge firmly up and into the slot until it snaps into place.
c) Make sure both cartridges are secure, Close the print cartridge door.
6) Align the print cartridges.
a) Press OK to print the alignment page, (Make sure you have loaded plain white paper in the bottom tray,)
b) Remove the alignment page from the output tray.
c) Place the alignment page face down into the document feeder.
d) Press OK to scan the alignment page.
After the page has scanned, alignment is complete.
Hope this helps. Please rate my response.
Thanks
Have a good day.
Dec 01, 2009 | HP Office Equipment & Supplies
Loading the ink cartridge
Please remember to rate other users who assist you for free :)
How to install or remove ink cartridges To print normally, install or remove ink cartridges in an orderly procedure.
Sep 29, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Krups Small Appliances Espresso Machine Logo
21 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
