The printer was working fine. It can up with a message to replace to replace MALAYSIA cartridge. I replaced the cartridge, and then a ERROR: message came up 0xc18a0101. I turned off the printer, and unplugged it for a few minutes. Plugged it back in , and turned on the printer same problem. I also tried another cartridge with no luck. I called HP and they were no help. Can anyone HELP me out.
  • msheats May 09, 2009
    No! Still have the same problem.
  • 916 Answers
Ink system failures this is a common problem.
If you have this problem you should be ready to replace your printer.
However there are still troubleshooting steps that you can do to try to resolve this issue.
Try this Ink System Failure Trouble shooting guide.
Posted on May 07, 2009
How do I fix e07
I assume you have a Canon copier based on the E007 error code. The Fuser fixing film is torn and the Fixing film assembly or the entire fuser should be replaced. Very common issue.......You cannot reset that code without first replacing the part causing the code.
Dec 03, 2014 | Office Equipment & Supplies
Cartridge Error - see user manual
It seems that you have tried most of the troubleshooting steps to identify and fix the problem. But try to replace your black cartridge with a new genuine Lexmark cartridge to determine if it's a faulty cartridge issue.
You may also contact Lexmark Technical Support Center for additional assistance.
Jan 24, 2012 | Lexmark X4650 InkJet Printer
Error Message. Please replace the following cartridge to resume printing. However, even after replacing cartridges, I still get the error message.
There could be a problem with the printer itself and not with the cartridges. You should try removing the cartridges and cleaning the cartridges carriage (the place where the cartridges "sits"), and especially those golden spots - the electric contacts that allow the printer to "read" the cartridge. The best way to do it is using a cotton ball or a ear tip dipped in alcohol, and then cleaning it. After that, try to re-insert the cartridges and see if the error message comes up again.
If it doesn't work, you can try cold resetting the printer - Turn on the printer, disconnect the power cord (while it still on), and then Press and hold the # and 6 buttons. While you're holding those two buttons, reconnect the power cord and keep holding those buttons until the color graphics display becomes blank. Then you can release the buttons. Press on the On button and trying using the printer now, should work fine.
Hopes that helps, Good luck!
Feb 18, 2011 | HP Photosmart C6180 All-In-One InkJet...
Ink cartridge is not compatible for c4780 message error appear on my printer display. I bought this printer in UK and replace a brand new original ink cartridge from Malaysia. Please help me to resolve...
You may have a dud. Try using the cartridge in another printer of the same model. Otherwise return it to the store and have them test it or exchange it for another one.
Jan 07, 2011 | HP PS C4780 All in One InkJet Printer
Says cartridge error 50C, see manual but i can't fix it
The error basically seems to mean that one or both of the cartridges is defective. It had me take out one cartridge and see if the error happens again.
I had both cartridges in and I got the error message2.gif. I took out the color cartridge and the error message went away. I put the color one back in and I got the error message again.
I replaced the cartridge and everything works fine.
Nov 09, 2009 | Dell A940 All-In-One InkJet Printer
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
"remove and check cartridge" error message
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=buu02180&cc=in&lc=en&dlc=en
I resolved the "remove and check cartridge" issue after reading the instructions at the above address. Most importantly, I replaced both cartridges and the problem was resolved.
The color cartridge appeared to be the issue. It had been in for months and used infrequently.
May 30, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Changing cartridges
I just turned on my hp psc 750 and an error message appeared. Incorrect black cartridge installed
I just used it yesterday, what is wrong???
Nov 06, 2007 | HP PSC 750 All-In-One InkJet Printer
53 people viewed this question
k24674
jasbo
jasbo
