Question about Samsung LN40A650A LCD TV
Channel changes by itself
Somehow it started on 04/15, and has been happening every sunday. The tv will drop the cable connection and the channel will change by themselves.
    Scholar:
  • 86 Answers
There is a button on the remote when if pressed will surf through all the channels on its own.Other than that you have a ghost in your house and should evacuate imediatly.
Posted on May 07, 2009
Why does my TV change channels or change options like it is scanning or as if someone is holding down a button on a remote
This happened to me before. If you have a cable box, take it back to the cable company and replace it. Also let them know what is happening.
Jun 23, 2012 | Samsung Televison & Video
Can't get TV picture after hooking up PS 2
How many sets RCA ports (for Video 1 / Video 2 so on and on) does your TV have?
Jul 26, 2008 | Panasonic Televison & Video
Zenith PV4663RK Rear Projection TV - Manufactured - Mar. 1995
Are you connected to cable TV using a digital receiver? If so, your TV can only get the signal for one channel - the one you're tuned into on your receiver. A workaround is to connect the coax cable TV cable directly to your TV, as well as connecting your receiver to your TV. This will allow you to be able to change the channel on your receiver and be able to change the channel on your TV to one of the analog channels you can tune into by connecting the coax cable directly to the TV.
Jan 09, 2008 | Zenith IQB50M90W 50" Rear Projection...
Can my netbook and or laptop be a remote to change channel on dishnetwork tv
I don't think so - the TV box would have to be connected to the netbook somehow for this to happen.
Mar 06, 2011 | Computers & Internet
Sony kdl46w5150 with external antenna dropping signal on some channels
1. Check for any loose connections starting at your TV. (Coaxial cables unscrew themselves with vibration...) Check all outdoor connections for corrosion and cut off and replace any cable ends that show corrosion.
2. Check your alignment - (positioning or pointing)
http://www.wowvision.tv/OTAalignment.htm
3. Replace the balun a.k.a. 75 ohm matching transformer.
If these don't work, a larger antenna is needed...
with one exception:
That exception is if your signal is too high. If this is the case, change alignment to reduce signal a little.
Jun 11, 2010 | Sony Televison & Video
Broadcast fail to show (E202)
U just take ur tv original remote just turn to channel 3?Why is ur cable service connected to channel 3?The proper way to connect to cable service is get the pay cable connected.Take ur original tv remote.Push Menu on ur remote,go to SET UP go down the CH Setup,pick cable,than scan for all the pay cables channels you pay for.
Mar 31, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
Cant maintain internet conntection simutaneously on my 3 devices
what is happening is ur voice frequency is bleeding in to the ur digital frequency
what u have to do is change channels of frequency on ur router
type 192.168.0.1 or 192.168.1.1 for most routers
in address bar and that should take u in to the interphase of router then go to wireless settings and change the channel that ur running on
rate my service pleas , July
Apr 10, 2009 | Computers & Internet
Channel keeps changing
it seems to be continusly scanning channels and never ends
Jun 28, 2008 | RCA F32649 32" TV
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Samsung LN40A650A LCD TV Logo
380 people viewed this question
Henry  Thomas
Henry Thomas
