Question about Health & Beauty
Meaning of foot spa basin - Health & Beauty
It worked fine the last time I used it, now it will not make bubbles. What should I do?
Review- Deluxe Bubble Bliss Foot Spa by Hometics ...
? 5:14
https://www.youtube.com/watch?v=LUBHAmA0y3A
Apr 17, 2014 - Uploaded by Calla
I love this bubble spa, its great for anyone who is on their feet all day, Its ... my machine quit working for the bubbles ... My mom bought one yesterday, but it does not bubble. ... make them a little larger so you could submerge your whole foot in ... I'm curious if you've ever used essential oils during your foot ...
The Next Best Thing to a Jacuzzi - Epinions.com
www.epinions.com/.../HoMedics_Bubble_Spa...2/.../130896793220
Jan 29, 2016 | Homedics Fb-50 Bubble Bliss Deluxe Foot...
Helen troy foot spa
Review of hot spa by Helen of troy - YouTube
? 6:49
https://www.youtube.com/watch?v=GbyHTxzTabY
Mar 15, 2012 - Uploaded by Mrsdarkness2011
Review of hot spa by Helen of troy .... i have this same foot spa. pros: is it can heat cold water, cons: doesn't have adjustable heat temp, not ...
Helen Of Troy Hotspa Professional Ultimate Foot Bath
footbathreview.net/helen-of-troy-hotspa-professional-ultimate-foot-bath
An unbiased review of the Helen Of Troy Hotspa Pro foot bath. Helen Of Troy offers several professional foot spa products and this foot bath has one of the.
www.amazon.com > ... > Electric Massagers
Amazon.com, Inc.
Rating: 3.8 - ‎12 reviews
Amazon.com : Helen Of Troy Hotspa Professional Ultimate Foot Bath : Foot Bath ByHelen Of Troy : Beauty.
Helen of Troy Europe Owners Manuals »
www.hot-europe.com/support/owners-manuals/
Dedicated to delighting the consumer. We aim to make reliable & long lasting products. However, in the unlikely event that your appliance requires servicing ..
Jan 13, 2016 | Hotspa Helen of Troy Professional Foot...
How to fix sunbeam foot spa
if it has an air switch check to see if air hose isnt broke or kinked if it has a motor to produce bubbles make sure it works
Aug 23, 2014 | Pool & Spa
Can i ask what is the basic meaning of foot spa
foot spa helps to relieve the hot itchiness in your feet, remove the dry flaky skin and yes it does make it softer. if you are using sterioid cream or any gel like creams,always put this on after a luke warm foot spa, do not dry the skin completely, shake your feet then apply the ointment, use a small amount, wrap your feet in glad wrap for 1/2 hour, your skin will feel soft, pain free and pampered, glad wrap helps the ointment absorb into the skin. I suffer from some type of skin cirrhosis
recommended by my dermatologist: Lovey Harrison
Aug 17, 2011 | Health & Beauty
The flexifoot on my old baracuda is split
What do you mean by flexifoot, and what do you mean split? The large rubber disc is called the "durometer" disc (on the G3 it's called a finned disc). The small rubber pad the the big one fits over is called a "foot pad", the foot pad fits over a hard piece called the foot plate. That being said.... if your referring to the durometer disc being split, or torn, I assume it is very worn out and needs to be replaced. if it's new and torn then it may still work fine. if it is worn out chances are you need to replace the foot pad, and possible a couple other pieces.
Sep 16, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Water in pool fountain drops when pump is shut off.
Back flow preventer (check valve) in pump is failed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Aug 26, 2009 | Henri Studios Henri Studio 5215f17 Three...
Water not staying in basin for wash
The drain hose must go above the highest point of water in the tub before entering the drain or it will siphon out. Add pipe to get above the top of the washer or add hose and raise it up.Make sure there is a air break between the hose end and the trap or it will be all for not. Eric
Aug 12, 2009 | Washing Machines
Health & Beauty Logo
458 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
