Question about HP Compaq nx7400 Notebook
Battery power died and the power cord will not charge or trun on the computer
The battery died and the power cord is not charging the battery or allowing it to power up
  • HP Master
  • 32,281 Answers
When you plug in the adapter into the laptop a LED lights up to indicate that it is connected to the mains supply and is charging.
The adapter is faulty or the connector is not making proper electrical contact. Wriggle the connector plug to see if the charge light comes on, if it does then the loose connector needs repairing.
Check the adapter with a multi-meter, the voltage reading should be a slightly higher than the voltage that is printed on the label on the adapter. If the voltage is more than 10% below the nominated voltage then replace the adapter it is faulty.
Posted on May 08, 2009
Battery is not charging
If the laptop works with the power plugged in, the battery is most likely exhausted and needs a replacement.
Nov 14, 2013 | Acer Aspire Computers & Internet
Acer Aspire One battery only charges to about 23%
Sadly, the only other thing you can do is buy a new battery in this instance; or continue with what you're doing.
One of the things you could do, is do not charge the computer until it dies. Batteries have a life span, and this as you may or may not know is reduced by charging, or even worse damaged more by just keeping it plugged in, charging it when it's half way charged and such on so fourth. You can increase life span by just letting it die, and then recharging it. It sounds like your battery has got to a weak point from all that charge, unplug, fall, charge. I apologize for your battery.
Feb 23, 2013 | Acer Aspire One Netbook
Asus UL50VT always shows charging
Either your battery or the power cord has an issue. Does the battery ever fully charge and make the charging light disappear or turn green? If not the battery could be bad.
Try running the computer off the battery by removing the power cord. if the battery starts losing charging strength real quick then your battery is bad. I've see bad batteries that say they are 100% charged but as soon as you remove the power cord it gets down to 5% i a matter of minutes.
Try running the computer on just the power cord. If it stays on and lets you operate without any problem then the power cord is good. A good power cord will not charge a bad battery.
If the laptop does not let you stay on long with the power cord, then either the power cord is bad or the DC Power Jack where the power cord plugs into the laptop is bad. If either of them is bad they will not charge a good battery.
Check your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Jun 06, 2012 | Computers & Internet
Asus always shows charging
Jun 06, 2012 | ASUS UL50Vt Notebook
No power will not trun on
Hello
Plug in the printer power cord into electricity to charge the battery.The battery might need charging if the On light flashes green it indicates that the battery is charging.
Switch ON the printer, the battery charging icon (lightning bolt icon) flashes above the battery icon on the printer screen to indicate that the battery is charging.
If the battery is charged and the printer does not turn on with the battery power, unplug the printer power cord, if it is plugged in. Open the battery compartment and remove the battery. Wait for about 10 seconds, and then reinstall the battery.
An empty battery should fully charge in approximately four hours when the printer is not in use. If the battery still does not charge in 4 hours,you should replace it
Good luck
Apr 23, 2010 | HP PSC 2210 All-In-One InkJet Printer
HP zd8000 will not charge battery or run on power cord
check the dc jack probably is loose that cause the batterie dont get charge
Aug 13, 2009 | HP Pavilion zd8000 Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Do you have another power cord to check? Most places like bestbuy is willing to let you test a universal power cord for your type of laptop before you buy. Usually in your case, the power cord or connector has gone bad. If you test the laptop at the store and it doesnt work then its your connector but if it works. you could consider buying that power cord.
May 07, 2009 | Computers & Internet
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
The little orange light that comes on when the computer is charging just flashes and computer wont trun on what does this mean?
Make sure the power cord is securly connected to the computer and that it plugged in. Are you sure the battery isn't emty?
Try taking out the battery and leave the power cord plugged in and try to turn it on.
Mar 13, 2009 | Acer Aspire 4720 Notebook
Power
Did the battery seem to lose it's charge rapidly prior to this, this would be an indication of a battery losing it's useful life, or a problem with the charge system.
Have you tried to take the battery out, plug the computer to a wall outlet granted you have the power adapter which is the same as the charger cord I would think. If that works I would say you need a new battery. Sometimes the plug port where it connects in the computer wears, so try and wiggle the cord if you didn't get something the first time.
Matt
Nov 20, 2008 | Acer Aspire 5500 5570-2609 Laptop
HP Compaq nx7400 Notebook Logo
252 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
